I am still in the initial learning using a 20x1. I successfully drove a unipolar step motor and now I would like to drive it using at the input a quadrature encoder taken from a computer mouse. The sequence code of the encoder is the same as the output sequence but I need to read the two inputs simultaneously and generate the outputs in accordance. This will allow to turn the step motor with a knob connected to the input encoder.
Reading the manual sec. 3 I found the setint command only capable of this but I think there is a better way to do it.
Can you please help?
