when using the READTEMP on C port
it turns off pins on B port
just wondering why ?
not too bad can turn back on again using LET DIRSB= %11111111
when using HI2CSETUP I2CMASTER
sda scl pins remain in a high or low state when not used
can not control these pins using let pinsb =
HI2CSETUP OFF does not seem to restore control
having to do a RESET
is there a way to restore control without doing a RESET
when using READ WRITE commands
how many operations can be performed
before you can no longer write
Thanks in advance !!!
