I would like to send two variables from one PICAXE (attached to two variable resistors) to another using wireless modules. The PICAXE receiving the variables will be using them to adjust the speed of a motors (via PWM) attached to a dual motor gearbox - allowing independent control of the left and right wheels (it is the item found here: http://www.littlebirdelectronics.com/products/Tamiya-89915-Twin%2dMotor-Gearbox-Kit-%2d-Clear.html).
Anyway, I know what to do with the PICAXE code side of things, however, am not really sure about what wireless module to choose. I am planning to use an 08M/14M (ADC-->Tx) and 28X1 (Rx -->PWM) for this.
Are the ones that are mentioned at the link below reliable enough to use with moving objects? Hopefully someone here has used them. The unit the gearbox will be used in will be moving no more than about 5-10 kilometers per hour (I personally think they should be okay).
http://www.picaxe.orconhosting.net.nz/txrx433.jpg
They are only $10 AUD each from Jaycar Electronics. I am only after something 10-20m range max - I don't want to use infrared. And I only need a Rx module and Tx module - not one with both (I think called a transceiver).
There are also some cheap modules on eBay:
Tx: http://cgi.ebay.com.au/1000m-RF-Wireless-Radio-Transmitting-Module-TM1000-1_W0QQitemZ290368703543QQcmdZViewItemQQptZRadio_Control_Vehicles?hash=item439b52cc37
Rx: http://cgi.ebay.com.au/Wireless-Radio-Superheterodyne-Receiver-Module-RM1SH_W0QQitemZ300365598720QQcmdZViewItemQQptZGarage_Doors_Openers?hash=item45ef2f5000
If any one has anymore ideas, I'd be interested to know. I don't want to spend more than about $30 AUD on this.
Thanks for your help in advance.
