Digital to Analog Converters 101
Digital to Analog Converters (DAC’s)
This attached tutorial is a follow-on to my earlier Digital Potentiometers 101 tutorial which I prepared in December 2009.
For the Digital Potentiometer tutorial, see this thread:
http://www.picaxeforum.co.uk/showthread.php?t=14087
This tutorial covers the R-2R resistor network concept and the Microchip MCP4821/4822 with SPI interface. The code was test on the MCP4822.
forum member Janne has a further code snippet for the MCP4921/4922 at:
http://www.picaxeforum.co.uk/showthread.php?t=14595
For most intents and purposes, the MCP4821/4822 and the MCP4921/4922 are identical from a program control viewpoint
DAC's part 2
The attached tutorial is an extension of that provided above and covers the Microchip TC1321 single channel 10-bit i2c comms based DAC.
The TC1321 is a relatively simple device but does provide i2c based comms and is available in an 8-pin SOIC package with can easily be soldered to a SOIC to DIP adapter if required.
