I'm trying to get these boards to work with the XBee series 2 modules. I have got two of them all wired up and I am following the tutorials word for word but still seem to have problems. For the very first tutorial it tells you how to configure the XBees, it works fine for board A (the one with the sp3232 or max3232 chip in it), but it doesnt seem to connect to board b (with the picaxe chip). I dont think its the board as when I swap the chips around and adjust the jumper it works fine. Is this normal?
Also what should the three leds be doing when turned on with no code. My leds are as foolows:
RSSI - off
STAT - on
IND - on
Is this normal?
I have tried just moving onto the second pinging tutorial and these RSSI led does not light up and the serial terminal just says "No response".
Another potentially silly question, on the board there is a space for a push button if you are using the board with a GPS, on the board under the button it says "CONNECT", I assume this is just the name of the board rather than an instruction as it mentions nothing in the manual about this.....
Cheers,
Mike
RSSI - off
STAT - on
IND - on
Is this normal?
Cheers,
Mike
