I'd be interested if anyone has ideas on how to measure the duration of a camera flash. The duration is normally taken to be the time it takes for the flash to rise to 25% of peak power and then drop down to the same level again. Timings are often in the region of 10 microseconds. Accuracy would need to be about +-10% and could be averaged over a number of tests.
You can see some related info and graphs here...
Discharge Curves For Electronic Flash
I can't imagine that there is a Picaxe only solution to this but is there some suitable circuit that could be used. I understand that the best way is probably to use a scope but I'm thinking of a more portable solution.
Any ideas welcome.
Any ideas welcome.
