If you have the time could you give my Picaxe ROV schematic a look? I want to be sure everything is good before I breadboard it.
Notes:
-The PA18X up top is in the control box. Everything in the lower part is onboard the ROV.
-+2 is 5v from the 7805, + is 12v straight from the battery.
-JS = Joystick w/ two 10K pots (only one pot is used on JS2)
-The voltage divider on the 28X1 is to check battery voltage.
-The LEDs and buzzers on the 18X are for general indicating.
-Yeah, my component shapes are wrong. Sorry about that.
Thanks in advance, and be sure to post with any questions.
http://h1.ripway.com/bananafred/colin2.gif
EDIT: I have updated the schematic with my new enlightendness on MOSFETs etc. and created a breadboard with PEBBLE (which by the way is amazing).
So if you could have a look at my breadboard and do the same as before...
I left out the relays and motors because there is no good way to put them on the breadboard. Just assume that they are hooked up with the drain of the MOSFET on one side and +12v on the other side of the coil.
Notes:
IC||443|270|1||U?|||PICAXE28|IC||PICAXE28_1
Wire||207|270|2|||#FF0000|3||||
Wire||207|105|2|||#CC6633|2||||
Resistor|4300|373|372|1|Resistor|R?||3||IC||
Wire||210|404|1|||#DFFF00|6||||
Note||1224|97|1||||||12V+||NOTEPAD_1
Note||1219|63|1||||||0V||NOTEPAD_1
Resistor|2200|471|409|2|Resistor|R?||3||IC||
Transistor|BC559|344|195|2|Transistor|Q?|||2|IC|SDG|transistor_22
Wire||342|105|2|||#CC6633|2||||
Resistor|82|400|236|1|Resistor|R?||1||IC||
Wire||480|184|1|||#DFFF00|13||||
Resistor|1000|831|208|1|Resistor|R?||2||IC||
Transistor|BC559|856|140|2|Transistor|Q?|||2|IC|SDG|transistor_22
Wire||855|105|2|||#CC6633|2||||
Terminal||924|238|1||TS?||3|4|Terminals||terminal_431
Wire||963|105|2|||#CC6633|2||||
Wire||990|270|2|||#FF0000|9||||
Wire||561|239|1|||#DFFF00|14||||
Wire||314|104|21||12|#FDFF00|11|14|||
Wire||479|240|13||11|#FDFF00|13|11|||
Wire||560|240|11||11|#FF9900|15|11|||
Wire||935|104|21||11|#FF0000|3|11|||
Wire||989|77|21||11|#FF0000|3|11|||
Wire||844|77|22||11|#FF0000|4|11|||
Wire||587|231|12||11|#3253FF|17|11|||
Terminal||1005|183|1||TS?||3|4|Terminals||terminal_431
Wire||1070|77|21||11|#FF0000|3|11|||
Wire||1018|269|23||11|#CC6633|10|11|||
Wire||342|77|21||11|#FF0000|3|11|||
Resistor|82|750|372|1|Resistor|R?||3||IC||
Resistor|82|777|456|1|Resistor|R?||1||IC||
Wire||829|432|11||11|#FF0000|7|11|||
Transistor|BC559|883|333|2|Transistor|Q?|||2|IC|SDG|transistor_22
Wire||881|407|21||11|#FDFF00|4|11|||
Wire||856|396|12||11|#FF0000|3|11|||
Transistor|BC559|964|333|2|Transistor|Q?|||2|IC|SDG|transistor_22
Wire||962|407|21||11|#FDFF00|4|11|||
Wire||641|203|12||11|#3253FF|19|11|||
Wire||614|188|13||11|#00A060|23|11|||
Transistor|BC559|1101|250|2|Transistor|Q?|||2|IC|SDG|transistor_22
Transistor|BC559|1182|250|2|Transistor|Q?|||2|IC|SDG|transistor_22
Wire||1099|77|21||11|#FF0000|3|11|||
Wire||1180|77|21||11|#FF0000|3|11|||
IC||1362|270|1||U?|||PICAXE08|IC||PICAXE08_1
Wire||656|214|22||11|#FF0000|12|11|||
Wire||683|214|22||11|#000000|11|11|||
Resistor|33000|581|410|2|Resistor|R?||3||IC||
Wire||639|462|21||11|#CC6633|2|11|||
Wire||506|176|12||11|#A233C3|31|11|||
Wire||1342|269|21||11|#FF0000|3|11|||
Wire||1344|451|12||11|#FF9900|4|11|||
Wire||1317|405|11||11|#FDFF00|4|11|||
Resistor|82|1265|374|1|Resistor|R?||1||IC||
Transistor|BC559|1209|333|2|Transistor|Q?|||2|IC|SDG|transistor_22
Wire||1207|462|21||11|#FF0000|2|11|||
Wire||1369|462|21||11|#FF0000|3|11|||
Wire||1369|77|21||11|#FF0000|3|11|||
Resistor|82|1454|237|1|Resistor|R?||2||IC||
Transistor|BC559|1479|195|2|Transistor|Q?|||2|IC|SDG|transistor_22
Wire||1477|77|21||11|#FF0000|3|11|||
Transistor|BC559|209|388|2|Transistor|Q?|||2|IC|+I G +O|transistor_22
Wire||207|77|21||11|#FF0000|11|11|||
Wire||234|77|21||11|#FF0000|11|11|||
Wire||261|462|21||11|#FF0000|3|11|||
Wire||927|242|22||11|#FF0000|11|11|||
Resistor|4700|447|465|2|Resistor|R?||2||IC||
Resistor|33000|1394|465|2|Resistor|R?||1||IC||
Wire||324|405|11||31|#FDFF00|2|31|||
BREADBOARDSTYLE=BB36
