I have been reading the philips/nxp i2c protocol datasheet!
I have searched the picaxeforum and have not found answers to these questions:
I have not used the Picaxe / Picaxe-i2c enough to know.
BROADCAST - i2c supports a broadcast control byte
Does the Picaxe implementation support the BROADCAST control word? 00000000
more at http://www.i2c-bus.org/addressing/general-call-address/
10-BIT ADDRESSING - i2c supports 10-bit addressing
Does the Picaxe implementation support the 10-bit addressing scheme?
more at http://www.i2c-bus.org/addressing/10-bit-addressing
MULTI-MASTER - i2c supports a multi-masteri setup
Does the Picaxe implementation support the logic necessary to comply with the multi-master portion of the specification?
more at http://www.i2c-bus.org/MultiMaster/
Thank you for your kind replies!
kewakl
kewakl
