Manie: is that a colpitts osc? There are a few circuits. Simple ones are fine,
but may have problems being consistent if you build a million of them, may drift, and have sensitivity to supply voltage and load changes.
There are some sine synth chips out, mostly for RF work, but some go down pretty low, don't have any part numbers right now. I have used 2 improved techniques in the past, but if was to do today would probably hunt for a single chip that does it.
The first method used a crystal locked square wave clock to control a switched capacitor filter, the clock speed was about ten times faster than the "signal" freq, so you need two clocks. I was getting some tiny steps in the waveform, the manuf said it was because I did not have a ground plane board. Maybe, I just added an rc filter and it cleaned it up.
The second trick was a PIC chip spitting out a sine table into a D/A. I got clever and realized all I needed was 0-90 degrees data. For the second quadrant, played it backwards!
For the 3rd and 4th, repeat, but switch polarity. This solution actually was never used, it was for a giant UPS inverter. Just playing around...
Anybody like my amplifier??? It really is just an extension of the "boosted opamp" circuit you can find in databooks, the npn/pnp driver. It gets weird with the transformer coupling, but is fun. I've been building circuits and reading about them for 4 decades, ham radio, shortwave, Heathkits, school. Have never seen that config before. No one asked why there is no base resistor. It works without it. If the output pair (I think I paralleled a couple) is driving 10A, with a beta of 10, then a 1A base current is about right, which the EL2008 can supply. At lower loads it might be overdriven. If I make another one will try a base resistor. Any other suggestions are welcome.
