[Edit 06.04.09]
The Problem has been resolved:
The problem was that Vista automatically Installed the device and used a different a driver version than provided by Rev-Ed: It installed 2.0.0.19, but the correct ones are 2.0.0.7.
If you find yourself in this situation use the "Update Driver"-Button in the Device Mananger/Ports/Prolific... /Properties/Driver, there you can manually Browse your computer and select the folder downloaded from Rev-Ed (link on top of this/any page).
[/Edit 06.04.09]
Hello Forum,
I'm having trouble programming my PICAXE chips with my new Rev-Ed USB to Serial Adapter (USB010). It gives me the following error message:
" Serial port error - code 0x1F54 'Error reading comm device' "
I also have the following strange behaviour:
Test Program (downloaded from laptop with serial port):
When I attach the Cable USB010-AXE026-combo the PICAXE semi hangs:
I) When already running it will finish the program but pushing the reset button won't make any LED light up again.
II) When Programing Cable is inserted before the program starts running no LEDs are lit.
When I remove the Download Cable reset works again.
This behaviour is very erratic, so what I describe above is what happens MOST of the time, sometimes the PICAXE needs a complete power cycle to run the program again, on a few occasions inserting the cable while the program is running will "freeze" the current LED pattern until the program finishes (If cable is inserted when both LEDs are lit up they both are turned off 2 seconds later, if cable is inserted at start of program only one LED turns on , it turns off 3 seconds later). Point II might be a variant of this*
My setup:
- Laptop with Windows Vista (Professional), no serial port (obviously)
- Picaxe 40X1 (about 9 months old) on Rev-Ed Protoboard (AXE022)
- RevEd USB-to-serial-converter (USB010) attached to a normal Rev-Ed Serial Download Cable (AXE026)
- PICAXE Programming Editor Version 5.2.2
- I have selected the correct port (port4)
- 3 AA batteries power supply
The drivers for the USB010 came from a Rev-Ed CD, Installation was easy and without problems (once I bothered to insert the CD )
I tested the PICAXE (on the AXE022 with the Rev-Ed Standard Download Cable) with an older laptop (Windows XP [home edition?],serial port, older version Programming Editor [about 12 months old] and everything was fine (that's how I got the program downloaded in the first place).
Can someone offer some insights on this issue?
What is: Serial port error - code 0x1F54 'Error reading comm device' ?
regards
Florian
* Output state is frozen when zero LEDs are lit, observing current consumption might reveal if the PICAXE is doing something, but I don't wanna bloat this thread (yet).
[Edit 04.09]
Replaced AXE010 with USB010, also in thread title
[/Edit 04.09]
[/Edit 06.04.09]
Hello Forum,
high 0 ' turn on LED0
high 1 ' turn on LED1
low 1 ' turn off LED1
low 0 ' turn off LED0
My setup:
regards
Florian
[Edit 04.09]
[/Edit 04.09]
