#picaxe 28x1
setfreq m8
TABLE 0,(0,55,0,83,0,110,0,138,0,165,0,193,0,221,0,249,1,21,1,49)
TABLE 20,(1,77,1,105,1,133,1,161,1,189,1,218,1,246,2,19,2,47,2,76)
TABLE 40,(2,105,2,134,2,163,2,192,2,221,2,250,3,23,3,52,3,82,3,111)
TABLE 60,(3,141,3,170,3,200,3,230,4,4,4,34,4,64,4,94,4,124,4,154)
TABLE 80,(4,185,4,215,4,246,5,21,5,51,5,82,5,113,5,144,5,175,5,207)
TABLE 100,(5,238,6,13,6,45,6,77,6,108,6,140,6,172,6,204,6,236,7,13)
TABLE 120,(7,45,7,77,7,110,7,143,7,176,7,208,7,241,8,19,8,52,8,85)
TABLE 140,(8,119,8,152,8,186,8,220,8,254,9,32,9,67,9,101,9,135,9,170)
TABLE 160,(9,205,9,240,10,19,10,54,10,89,10,125,10,160,10,196,10,232,11,12)
TABLE 180,(11,48,11,85,11,121,11,158,11,195,11,232,12,13,12,50,12,88,12,125)
TABLE 200,(12,163)
symbol SCK = %11111101
symbol SCK_PIN = 1
symbol DAT = %11111011
symbol DAT_PIN = 2
symbol NDAT = %00000100
symbol t_in = 3
symbol h_in = 5
symbol my_trisc = 0x87
symbol heartbeat = 3
symbol halfclock = 10
symbol fullclock = 20
symbol zero=4010
hsersetup B9600_8,1 ' 9600 baud background receive
hserout 0,("Temp/Humidity Logger V1.0")
high heartbeat
gosub setup
gosub connectionreset
cycle:
gosub measuretemp
gosub measurehumi
debug
wait 5
goto cycle
end
setup:
peek my_trisc ,b27
b27 = b27 & SCK ' set the SCK as output
b27 = b27 | NDAT ' set DAT as input
trisc=b27 'clock under my control
low portc SCK_PIN ' force clock low, data is externally controlled
datout:
peek my_trisc ,b27
b27 = b27 & DAT ' set the DAT as output
trisc=b27 ' use the external pullup to set data high, clock under my control
datin:
peek my_trisc ,b27
b27 = b27 | NDAT ' set the DAT as input
connectionreset: ' routine to reset the chip
gosub datin
for b27 = 1 to 10
high portc SCK
pauseus fullclock
low portc SCK
pauseus fullclock
next b27
gosub transstart
transstart: ' routine to start a transaction
low portc SCK_PIN: high portc DAT_PIN' clock low and data high
pauseus halfclock
gosub datout ' set the clock and data as outputs
high portc SCK_PIN ' clock high and data high
pauseus halfclock
low portc DAT_PIN ' clock stays high, data low
pauseus halfclock
low portc SCK_PIN' clock goes low, data stays low
pauseus fullclock
high portc SCK_PIN ' clock high, data stays low
pauseus halfclock
high portc DAT_PIN ' clock stays high data high
pauseus halfclock
gosub datin
readbit: ' generate a clock pulse to read a bit into b1
pauseus halfclock
high portc SCK_PIN ' set clock high, data stays high
pauseus halfclock
b1=pins & NDAT
pauseus halfclock
low portc SCK_PIN' set clock low, data stays high
pauseus halfclock
writebyte: 'outputs the byte in b0
low portc SCK_PIN: high portc DAT_PIN ' data high and clock low
gosub datout ' set the clock and data as .outputs
if bit7=0 then: gosub clocklow :else gosub clockhigh: endif
if bit6=0 then: gosub clocklow :else gosub clockhigh: endif
if bit5=0 then: gosub clocklow :else gosub clockhigh: endif
if bit4=0 then: gosub clocklow :else gosub clockhigh: endif
if bit3=0 then: gosub clocklow :else gosub clockhigh: endif
if bit2=0 then: gosub clocklow :else gosub clockhigh: endif
if bit1=0 then: gosub clocklow :else gosub clockhigh: endif
if bit0=0 then: gosub clocklow :else gosub clockhigh: endif
gosub datin ' sets data back to an input
gosub readbit
readbyte: 'inputs a byte to b0, send ack if b1 = 1
gosub datin
b0=0
gosub readbit:if b1!=0 then: bit7 = 1:endif
gosub readbit:if b1!=0 then: bit6 = 1:endif
gosub readbit:if b1!=0 then: bit5 = 1:endif
gosub readbit:if b1!=0 then: bit4 = 1:endif
gosub readbit:if b1!=0 then: bit3 = 1:endif
gosub readbit:if b1!=0 then: bit2 = 1:endif
gosub readbit:if b1!=0 then: bit1 = 1:endif
gosub readbit:if b1!=0 then: bit0 = 1:endif
pauseus halfclock
if b5 = 1 then ' send an ack
low portc DAT_PIN
gosub datout
gosub clocklow
gosub datin
else ' send transfer complete
gosub clockhigh
clocklow:
low portc SCK_PIN: low portc DAT_PIN ' set data low
pauseus halfclock
high portc SCK_PIN ' set clock high, data stays low
pauseus fullclock
low portc SCK_PIN: low portc DAT_PIN 'set clock low, data stays low
pauseus halfclock
clockhigh:
low portc SCK_PIN: high portc DAT_PIN ' set data high
pauseus halfclock
pauseus fullclock
low portc SCK_PIN: high portc DAT_PIN ' set clock low, data stays high
pauseus halfclock
waitcomplete: 'put timeout code in here if required
low heartbeat
pause 20
b3=pins & NDAT
if b3 !=0 then goto waitcomplete
high heartbeat
measuretemp: ' read raw temperature data into w5
gosub transstart
b0 = t_in ' set measure temp command
gosub writebyte
gosub waitcomplete
b5 = 1
gosub readbyte
b11 = b0
gosub readbyte
b10 = b0
b5 = 0
gosub readbyte
if w5> zero then
w5=w5-zero
w1=w5//100
w1=w1/10
w5=w5/100
hserout 0,("Temp=",#w5,".",#w1,"°C,")
w5=zero-w5
w1=w5//100
w1=w1/10
w5=w5/100
b0 = "-"
hserout 0,("Temp=",b0,#w5,".",#w1,"°C,")
measurehumi:'read raw humidity data into w6
gosub transstart
b0 = h_in
gosub writebyte
gosub waitcomplete
b5 = 1
gosub readbyte
b13 = b0
gosub readbyte
b12 = b0
b5 = 0
gosub readbyte
for b2=0 to 200 step 2 'lookup the raw humidity value in the table
readtable b2,b1
b3=b2+1
readtable b3,b0
if w0>=w6 then: exit: endif
next b2
b0=b2/2
hserout 0,("RH=",#b0,"%",13,10)
