I have a simple and very effective circuit based on a 14m, which monitors temperatures and switches a pump in to prevent overheating or freezing in a water circuit.
I am concerned that the system could potentially malfunction without the user realising, and damage could occur.
I would like to have an audible alarm which would trigger in the event of a power loss, program crash or temperatures moving outside of a permitted range.
I can see that I could use a completely separate circuit (8M) with independent battery power but wonder if anyone has found a way of incorporating the desired alarm functions into the main Picaxe program, as a sort of failsafe. Obviously the critical functionality would be tripping the alarm in the event of program crash, where it cannot be guessed whether a given pin would crash high or low, if you follow me.
Any thoughts will be welcomed.
