Having seen cases where members are trying to connect larger or higher current rated stepper motors, I have spied that ST Microelectronics make a two IC solution that can be used for up to 4 Amps total (2Amps per channel) DC current.
Repetative peak current is 2.5 Amps per channel.
L297 controller chip http://www.futurlec.com.au/Others/L297.jsp
L298 "driver" chip http://www.futurlec.com.au/Others/L298.jsp
While a little more complex as a 2-chip solution than the L293D, they do allow for motors with higher currents.
Also located an ST Microelectronics Applications Note for the L297 chip:
http://www.datasheetcatalog.com/datasheets_pdf/A/N/4/7/AN470.shtml
Futurlec (at least here in Aust ) stock the L297 and L298 chips
