This is for those who make PCBs at home.
I want to make a 12inx8in PCB at home. I've bought the board from Maplin Electronics (for those from the UK) and the developer and echting chemicals. After researching a bit on the net i found that the developer is Sodium Hydroxide and not suitable.
I've also come across a few press and peel laser toner methods. I have a few queries.
1) Can I use press and peel method and then Etch it directly using Sodium Persulphate Echant
2) Most PCB making guides suggest using Ferric Chloride, my question is will using Sodium PErsulphate make any difference other than maybe the time it takes to etch the board.
3) have you got any tips regarding the whole process?
Thanks a lot for all the help esp since this is not directly related to PICAXE.
