​ ​ ​ ​ Picaxe 6.1.0.0 Editor Simulation Highlight Disappearing (Not Sequential)
Results 1 to 3 of 3
Thread: Picaxe 6.1.0.0 Editor Simulation Highlight Disappearing (Not Sequential)
  1. #1
    Default Picaxe 6.1.0.0 Editor Simulation Highlight Disappearing (Not Sequential)
    Hello All!
    I am having a simulation issue that just started happening. When I first installed the editor the progress yellow highlight stepped through each line of code letting me easily see where the program was in the simulation. Now the simulation highlight feature is only in a few spots as it runs and it is very difficult to see exactly what code line is next to be processed. I can see from the simulation variable monitor panel that the program is simulating properly so I know its just an issue with the highlight display feature. Please help I'm stuck in the mud!
    Thank you
    Brian K
  2. #2
    Join Date
    Jan 1970
    Location
    UK
    Posts
    24,438
    Default
    Two possibilities could be that it executing code lines contained within a macro or is executing code which is in other task if using an M2.
  3. #3
    Default
    I am not sure what an M2 task is but I noticed that this weird activity happened after I placed the following code in to set the processor speed;
    #freq M64
    once I removed it the editor simulation started working properly again!! Thank you!
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
