TB6612 Motor Control
SolidWorksMagi
I can make two motors run, but how do I make the two motors run simultaneously to drive straight forward or backwards?
; 28X2+TB6612FNG+2Motors.bas
#picaxe 28X2
symbol PWMA = C.1 ; B.0 Right Motor Speed Control
symbol PWMB = C.2 ; B.1 Left Motor Speed Control
symbol STBY = C.0 ; B.2 HIGH Allows the H-Bridge to Operate
symbol AIN1 = C.3 ; B.3 Direction Control
symbol AIN2 = C.4 ; B.4 Direction Control
symbol BIN1 = C.5 ; B.5 Direction Control
symbol BIN2 = C.7 ; B.6 Direction Control
symbol Speed = w2
Speed = 65000
gosub FWD
end
FWD:
high STBY ;. . . . . . ; C.0
pulsout PWMA, Speed ;.; 'C.2
pulsout PWMB, Speed ;.; 'C.1
low AIN1 ;. . . . . . .; C.3
high AIN2 ;. . . . . .; C.4
high BIN1 ;. . . . . . ; C.5
low BIN2 ;. . . . . . ; C.7
end
I also tried;
#picaxe 28X2
symbol Speed = w2
Speed = 65000
gosub FWD
end
FWD:
end
Still, only one motor turns ON at a time ???
I would have thought it were a simple matter of setting one of AIN1 and AIN2 high and the other low to make one motor turn in the desired direction, and then doing the same for BIN1 and BIN2 for the other motor. As to what settings those would be it would depend on how you have the motors wired and mechanically attached. You would need to experiment but it seems there's only two possibilities.
Then set the speed of each motor the same. I would have expected to see two PWMOUT commands to set the speed rather than PULSOUT.
SolidWorksMagi
Hi, Switching to PWMOUT fixed the problem! Thanks again hippy! You're a project saver!
Here is the code for the tests that is working!
#picaxe 28X2
symbol Speed = w2
Speed = 65000
gosub FWD
pwmout PWMA, 100, Speed ;.; 'C.2
pwmout PWMB, 100, Speed ;.; 'C.1
end
FWD:
end
