Symbol CS = B.1
Symbol WR = B.2
Symbol RD = B.3
Symbol TX = B.4
#Macro CMD_XXX( bits )
w0 = bits
Gosub Send
#EndMacro
#Macro CMD_WRITE( adr, dat )
; Data : %101aaaaadddd
CMD_XXX( %101 * 32 | adr * 16 | dat )
#EndMacro
#Macro CMD_DIGIT( adr, dat )
w0 = dat // 10
CMD_XXX( %101 * 32 | adr * 16 | w0 )
#EndMacro
#Macro SYS_DIS
; Data : %10000000000X
CMD_XXX( %100000000000 )
#EndMacro
#Macro SYS_EN
; Data : %10000000001X
CMD_XXX( %100000000010 )
#EndMacro
#Macro LCD_OFF
; Data : %10000000010X
CMD_XXX( %100000000100 )
#EndMacro
#Macro LCD_ON
; Data : %10000000011X
CMD_XXX( %100000000110 )
#EndMacro
#Macro TIMER_DIS
; Data : %10000000100X
CMD_XXX( %100000001000 )
#EndMacro
#Macro WDT_DIS
; Data : %10000000101X
CMD_XXX( %100000001010 )
#EndMacro
#Macro TIMER_EN
; Data : %10000000110X
CMD_XXX( %100000001100 )
#EndMacro
#Macro WDT_EN
; Data : %10000000111X
CMD_XXX( %100000001110 )
#EndMacro
#Macro TONE_OFF
; Data : %10000001000X
CMD_XXX( %100000010000 )
#EndMacro
#Macro TONE_ON
; Data : %10000001001X
CMD_XXX( %100000010010 )
#EndMacro
#Macro CLR_TIMER
; Data : %10000011XXXX
CMD_XXX( %100000110000 )
#EndMacro
#Macro CLR_WDT
; Data : %100000111XXX
CMD_XXX( %100000111000 )
#EndMacro
#Macro XTAL_32K
; Data : %100000101XXX
CMD_XXX( %100000101000 )
#EndMacro
#Macro RC_256K
; Data : %100000110XXX
#EndMacro
#Macro EXT_256K
#EndMacro
#Macro BIAS_HALF_2
; Data : %1000010abX0X
CMD_XXX( %100001000000 )
#EndMacro
#Macro BIAS_HALF_3
CMD_XXX( %100001001000 )
#EndMacro
#Macro BIAS_HALF_4
CMD_XXX( %100001010000 )
#EndMacro
#Macro BIAS_THIRD_2
; Data : %1000010abX1X
CMD_XXX( %100001000010 )
#EndMacro
#Macro BIAS_THIRD_3
CMD_XXX( %100001001010 )
#EndMacro
#Macro BIAS_THIRD_4
CMD_XXX( %100001010010 )
#EndMacro
#Macro TONE_4K
; Data : %100010XXXXXX
CMD_XXX( %100010000000 )
#EndMacro
#Macro TONE_2K
; Data : %100011XXXXXX
CMD_XXX( %100011000000 )
#EndMacro
#Macro IRQ_DIS
; Data : %100100X0XXXX
CMD_XXX( %100100000000 )
#EndMacro
#Macro IRQ_EN
; Data : %100100X1XXXX
CMD_XXX( %100100010000 )
#EndMacro
#Macro F1
; Data : %100101XXfffX
CMD_XXX( %100101000000 )
#EndMacro
#Macro F2
CMD_XXX( %100101000010 )
#EndMacro
#Macro F4
CMD_XXX( %100101000100 )
#EndMacro
#Macro F8
CMD_XXX( %100101000110 )
#EndMacro
#Macro F16
CMD_XXX( %100101001000 )
#EndMacro
#Macro F32
CMD_XXX( %100101001010 )
#EndMacro
#Macro F64
CMD_XXX( %100101001100 )
#EndMacro
#Macro F128
CMD_XXX( %100101001110 )
#EndMacro
#Macro TEST
; Data : %10011100000X
CMD_XXX( %100111000000 )
#EndMacro
#Macro NORMAL
; Data : %10011100011X
CMD_XXX( %100111000110 )
#EndMacro
Init:
; Datasheet C-Version
SYS_EN ; %100-0000-0001-X 0x02
RC_256K ; %100-0001-10XX-X 0x30
BIAS_THIRD_4 ; %100-0010-10X1-X 0x52
LCD_ON ; %100-0000-0011-X 0x06
Main:
CMD_WRITE( 0, 9 ) ; %101-aaaa-addd-d
CMD_WRITE( 1, 8 )
CMD_WRITE( 2, 7 )
CMD_WRITE( 3, 6 )
CMD_WRITE( 4, 5 )
CMD_WRITE( 5, 4 )
CMD_WRITE( 6, 3 )
CMD_WRITE( 7, 2 )
CMD_WRITE( 8, 1 )
Pause 5000
MainLoop:
w2 = 12345
CMD_DIGIT( 0, w2 / 10000 )
CMD_DIGIT( 1, w2 / 1000 )
CMD_DIGIT( 2, w2 / 100 )
CMD_DIGIT( 3, w2 / 10 )
CMD_DIGIT( 4, w2 )
Pause 1000
w2 = w2 + 1
Send:
High CS
High WR
High RD
Low CS
; Maximum of 16 bits output
b2 = 16
; Left align bits
Do While w0 < $8000
w0 = w0 * 2
b2 = b2 - 1
; Command in top three bits
b3 = w0 / $2000
Select Case b3
Case %100, %101 ;Command, Write
Low WR
If w0 >= $8000 Then
High TX
Else
Low TX
w0 = w0 * 2
High WR
b2 = b2 - 1
Loop while b2 > 0
End Select
High CS
