Drill file not showing in gerber viewers
jensmith25
I have created several PCBs in the past through DesignSpark PCB for SEEEDStudio manufacture but this time I'm having a problem where when I view the Gerber files, via an online Gerber viewer (tried several including SEEEDStudio EasyEDA one on uploading to manufacture) and the drill files are not showing up for any of the boards I want to produce.
I'm using DesignSpark PCB 8.1
It says it can't upload the drill file and says "Loading Excellon file 30mm_PCB.txt failed.
Project does not specify any drill hits"
Is this likely to be a problem for manufacture or is it just a random error. It's happening with 4 boards but not another that I plotted on the same day, so I'm sure the settings are correct in DesignSpark and the file looks like it normally does, as far as I can tell.
Drill file for one board.
G81
M48
INCH
T1C000.02500
T2C000.03000
T3C000.03150
T4C000.07087
T002
X00028250Y00019000
X00028250Y00029000
X00083500Y00018750
X00083500Y00028750
T003
X00047000Y00009750
X00057000Y00009750
X00067000Y00009750
T004
X00013000Y00067250
X00098000Y00067250
T001
G00X00024750Y00103250
M15
G01X00035500Y00103000
G03X00055000Y00080959A00019646
X00074500Y00103000A00019646
G01X00085000Y00103500
X00111250Y00072500
X00111250Y00032250
X00083250Y00000250
X00028750Y00000250
X00027500Y00000500
X00000250Y00032500
X00000250Y00072750
X00024750Y00103250
M17
M30
Any ideas?
jensmith25
Hi no, that's not what I mean. The board is fine. There are no errors.
I have made the Gerber files. When I am loading them into a Gerber viewer to check all is okay, the drill fine is not loading.
What I want to know is, if the drill file is correct and uploaded to SEEED as part of the zip file, does it matter if it's not showing in a Gerber viewer. Is this just a common problem?
I can't answer your question but someone at SEEED may be able to. Perhaps email them with your .zip file and ask them to confirm if the drill file is acceptable or not. Or perhaps ask DesignSpark.
I would have thought DesignSpark would produce industry standard files and that anything intended to show industry standard files would be able to show them if they conformed to that standard. But I don't have any experience with PCB design, the tools or files used.
jensmith25
I have asked on the DesighSpark forum but thought I'd ask here too as don't know how long will take to get a reply.
SEEED are on holiday until tomorrow and tend to be slow to respond. I need to progress these fairly quickly so it's a bit of a nuisance.
jensmith25
I've had a reply from DesignSpark technical support so it might be due to trailing zeros being off. Hopefully that will sort it. The drill file works in one Gerber Viewer he tried but not the free one, so might just be the gerber viewer itself.
