Paul Hoshovsky
Hello
Over the years there have been posts on the driving of stepping motors. Having read some of them, I would like to pose a question on how fast an 18M2 can drive an output pin to a stepping motor drive. I have written a very simple do loop code and measured on the scope the time elapsed between pulses. The code is:
high PinC.1
low PinC.1
For a 18M2 with the setfreq m32, I get a pulse length of 350 us (microseconds) and a high time of 100 us. If I change the code to
pulsout PinC.1,10
pulseus 10
For the same chip and frequency, I get a pulse length of 500 us with 40 us for the high time.
I must be missing something quite important. I don't understand how the max output frequency is less than 3kHz. Now I do understand about the overheads in the code generated by the compiler. Yet given that the clock frequency is stated at m32, I thought the output frequency at the pin would be somewhat higher.
It would be nice if someone would take a few minutes to confirm my numbers (assuming the scope, chip, etc is available). Or explain the reason why I cannot get a higher output frequency for the 18M2. The stepping motor drive spec sheet claims that it can accept pulses up to 200 kHz. I would like to prove that this drive manufacturer is correct. If I cannot get a higher speed, then I would need to look at external hardware or alternatives to validate the claim.
regards
Paul
high PinC.1
low PinC.1
pulsout PinC.1,10
pulseus 10
regards
Paul
