I have been using the HC-12 as a very simple remote for a while, works ok. However I dont understand why my variable b0 which is transmitted as a 1 becomes 6 on the receive side?
I have found like others that the newer HC-12 can only be used as pairs are discussed elsewhere. When I use an older HC-12 I get a number of 64 for b0?
Not sure what I've got wrong, can anyone guide me please. Peter
output C.0,C.2
input C.3,C.4,C.5, C.1
'TX Same program below working on both TOGGLE and HIGH OUTPUT when SWITCH PRESSED 3-5-18. THIS VERSION IS SWITCH ON/OFF ONLY
If pinc.4 = 1 then 'press c.4 switch to operate
b0 = 1 pinc.2 = 1 else b0 = 0 pinc.2 = 0 endif 'Checking b0 to put C.2 high to confirm b0 is 1
sertxd("The value of b0 is ",#b0,13,10)
serout C.1, N2400, (b0)
'RX below for high output on C.2 only when input switched on WORKING 3-5-18
b0 = 0
serin c.4, N2400, b0
if b0 = 0 then low C.2 else high C.2 endif 'Checking b0 number, should be 1 but why 6? LED on and relay switched by C.2
pause 100
