Dear all,
I'm trying to invent the wheel (I guess) by building a two-button motor controller. Press FWD button to start the motor in FWD direction slowly and 4 more times for more speed. Then press RWD button to reduce the speed down to zero and to three speeds backwards. Pressing FWD again, should allow going back to stop and speeding FWD again and so forth.
My hardware is 14M2 and the code (including a commented out servo section for incompatibility with pwmout reasons - hpwm did not work out of the box for me, so left it for later) pasted below. Apart from unscientific and maybe less than elegant code (pardon), my main challenge is why PWMOUT C.0, OFF does not switch PWM OFF. The square wave crest on the scope is not going anywhere and motor keeps humming at Speed = 4. Why?
Thank you for your time,
Edmunds
'Ship control
#picaxe 14m2
#no_data
'Flags
Symbol dirflag = bit0
'Byte variables
Symbol RudderPos = b4
Symbol Speed = w13
Symbol MainMotorDuty = w12
'Constants
Symbol SingleBtnDelay = 150
Symbol DoubleBtnDelay = 500
Symbol RudderRightMaxPos = 220
Symbol RudderLeftMaxPos = 80
Symbol ServoFullMoveDelay = 300
Symbol ServoStep = 5
Symbol MainMotorPeriod = 150
Symbol MainMotorStep = 20
Symbol MaxSpeed = 9 '~3.0V motor voltage
Symbol MinSpeed = 1 '0.0V motor voltage
Symbol SpeedStep = 1
Symbol DirCtrlVal = 4
init:
input C.3 'Go reverse BTN
input C.4 'Go forward BTN
input B.2 'Steer left BTN
input B.1 'Steer right BTN
output B.4 'Steering servo
output C.2 'Main engine PWM signal A
output C.1 'Main engine PWM signal B
RudderPos = 150
; servo B.4, RudderPos 'Initialise servo, set rudder to centre position, trimmer pot solution required
speed = DirCtrlVal 'corresponds to zero
if pinB.2 = 0 then 'If steer right button pressed ...
pause SingleBtnDelay '... ebounce the signal ...
if pinB.1 = 0 then '... and check if this is not a two button command
pause DoubleBtnDelay 'In case it is, debounce buttons enough and ...
toggle B.3 '... toggle NAV lights ...
pause DoubleBtnDelay '... debounce some more
elseif RudderPos > RudderLeftMaxPos then '... back to single button command steer right, limit max value ...
RudderPos = RudderPos - ServoStep '... and move rudder servo a little
; servopos B.4, RudderPos
if pinB.1 = 0 then 'Same as above, but for the steer left button
if pinB.2 = 0 then
toggle B.3
elseif RudderPos < RudderRightMaxPos then
RudderPos = RudderPos + ServoStep
if pinC.4 = 0 then
if pinC.3 = 0 then
toggle B.5
if Speed < MaxSpeed then
Speed = Speed + SpeedStep
sertxd ("Speed: ",#Speed,CR,LF)
if Speed >= DirCtrlVal then
low C.0
Select case Speed
case 4
sertxd ("At 1st 4!",CR,LF)
pwmout C.0, OFF
pwmout C.2, OFF
case 5
MainMotorDuty = 70
case 6
MainMotorDuty = 80
case 7
MainMotorDuty = 90
case 8
MainMotorDuty = 100
case 9
MainMotorDuty = 110
endselect
pwmout pwmdiv64, C.2, MainMotorPeriod, MainMotorDuty
low C.2
Select case Speed
case 1
MainMotorDuty = 90
case 2
MainMotorDuty = 80
case 3
MainMotorDuty = 70
case 4
sertxd ("At 2nd 4!",CR,LF)
pwmout C.0, OFF
pwmout C.2, OFF
endselect
pwmout pwmdiv64, C.0, MainMotorPeriod, MainMotorDuty
if pinC.3 = 0 then
if pinC.4 = 0 then
toggle B.5
if Speed > MinSpeed then
Speed = Speed - SpeedStep
low C.0
Select case Speed
case 4
sertxd ("At 3rd 4!",CR,LF)
pwmout C.0, OFF
pwmout C.2, OFF
case 5
MainMotorDuty = 70
case 6
MainMotorDuty = 80
case 7
MainMotorDuty = 90
case 8
MainMotorDuty = 100
case 9
MainMotorDuty = 110
endselect
low C.2
Select case Speed
case 1
MainMotorDuty = 90
case 2
MainMotorDuty = 80
case 3
MainMotorDuty = 70
case 4
sertxd ("At 4th 4!",CR,LF)
pwmout C.0, OFF
pwmout C.2, OFF
endselect
Edmunds
