Help with a FM tuner RDA5807M
John West
It appears to be software compatible with the TEA5767 IC, which has a lot more and better info available for it. I'd suggest you do a web search on that chip instead and read up on programming it. As you mentioned, this one has nearly no info on it.
premelec
@memi205 - Try forum "advanced search" feature upper right near a blank box on this screen on TEA5767 -
I don't believe you can link to the search results page with "?searchid=". Not sure what you should use.
Just entering TEA5767 into the search box at the top of this page and hitting return should do the job.
