Hello all,
I've been generating this output file when compiling for a long time now, and it has been working without any problems. Until today. The compiling still works fine, that's no problem, but now WordPad just opens an empty window and a separate error window telling that it cannot locate the file. The path given has my username converted to upper case letters, whereas it should be all lower case. When I navigate to where the file should be (\Users\<username>\AppData\Local\Temp\) then there are no .bas files there, suggesting that the problem lies on the file generation side.
As far as I'm aware, I haven't altered any settings in PE6, and neither have I downloaded any SW from RevEd recently. I've been through all the options set up and can't find anything that could affect the path name. Something somewhere must have changed, but I cannot find what or where. Can anybody help, please, I need the pre-processed file in order to run simulations.
