Jamiestyles
Hi all,
Any thoughts on the following?
I have built an RFID reader to be used in cross country races. The device saves RFID tag numbers with a timestamp into a CSV file on a VDrive2.
I developed it using the serial OLED 20x4 screen available on the picaxe store and it worked fine. It was powered by 3xAA batteries and the RFID range was about 10cm.
I then swapped the screen to a 16x2 OLED screen, again from the picaxe store, and the RFID stopped working. When I unplug the screen it worked fine, when I went back to the 20x4 screen it worked fine, but when the 16x2 screen was replaced it stopped.
I plugged the board into a mains power supply and the RFID reader worked with the 16x2 but the range was 0cm and only if I orientated it multiple times.
I feel it must be a power supply issue; however, I would have thought that the 20x4 OLED would be more power hungry than that the 16x2.
Any other ideas what it may be? I much prefer the 16x2 screen for the project, but it currently makes the project stop working..
Thanks for any advice and thoughts in advance.
Best wishes
Jamie
Best wishes
Jamie
