​ ​ ​ ​ twinkle little star
Results 1 to 7 of 7
Thread: twinkle little star
  1. #1
    Join Date
    Mar 2014
    Location
    maryland
    Posts
    64
    Default twinkle little star
    Need some guidance please...
    Working with my girl on a school project and we want to simulate a star in the sky. Trying to; run a LED @ 50% the whole time and to be able to give it a quick flash @100% as needed for the effect.
    Dave
  2. #2
    Join Date
    Jan 1970
    Location
    Colorado USA
    Posts
    3,201
    Smile
    Something to try is PWMOUT which can be varied for greater effect and then also have another pin to the LED through a diode where you turn that pin on and off with PULSOUT - with another resistor in series as well [i.e. 270 ohms in series with PWMOUT pin and say 150 ohms and a diode in series with the PULSOUT pin both to the same LED + pin with its - pin to V-]. RANDOM can be used for irregular twinkle times to trigger the PULSOUT flash.
  3. #3
    Join Date
    Apr 2013
    Location
    north dakota
    Posts
    483
    Blog Entries
    2
    Default
    @ premelec ....thats a good idea ... would a schottky diode work with that speed or would you use a normal one?
    I might give it a try
  4. #4
    Join Date
    Jan 1970
    Location
    Colorado USA
    Posts
    3,201
    Default
    At the PWMOUT speeds likely diode type doesn't matter much - mainly the diode voltage drop is your consideration - schottky diode has lowest voltage drop... I was assuming the pin drive current was all that was needed - if you have need for bigger current output than 20ma then use a LL MOSFET or two...
  5. #5
    Join Date
    Jan 1970
    Location
    UK
    Posts
    24,343
    Default
    You probably don't need PWMOUT. You can hardwire the LED fr the background brightness then just PULSOUT a pin to go low to create a brighter flash -
    -.- +V
     |              ___
     `---|>|---.---|___|--------( PICAXE
               |    ___
         LED   `---|___|---.
                          _|_ 0V
    Keep the PICAXE pin as an input normally, PULSOUT then execute another INPUT command.
  6. #6
    Join Date
    May 2010
    Location
    Newcastle Australia
    Posts
    326
    Default
    This program will flash the LED at a random time between 100 and 755 mS delay between flashes
    The minimum brightness of the led can be set by experiment and the duration of the flash can be set by the
    second pause.
    I tested the program with a standard LED.
    ' 08m2 program for star simulation
    setfreq M4
    pwmout c.2,100,0
    		random w0
    		w1 = w0/100 + 100  'Range between  100 to 855 mS
    		'debug
    		pwmduty c.2, 20  'this value is set for min dim level.  Found be experiment.
    		pause w1        ' random on time of minimum level
    		pwmduty c.2,400  ' led max ON
    		pause 20  'value in mS 100% LED on time.
    Bill
    In the interest of the environment, this post has been constructed entirely from recycled electrons.
  7. #7
    Join Date
    Mar 2014
    Location
    maryland
    Posts
    64
    Default
    Once again, thank you for your inputs! Her project is underway.....
    Dave
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
