techElder Well-known member Jan 10, 2018 #2 Check it out here: http://www.picaxestore.com/index.php/en_gb/picaxe/picaxe-chips/picaxe-chips-surface-mount/axe007m2sm.html
N Nelixuk2003 New Member Jan 10, 2018 #3 Texasclodhopper said: Check it out here: http://www.picaxestore.com/index.php/en_gb/picaxe/picaxe-chips/picaxe-chips-surface-mount/axe007m2sm.html Click to expand... Thanks Next question, can this be programmed using this: http://www.picaxestore.com/index.php/en_gb/picaxe/picaxe-starter-packs/axe091u.html
techElder Well-known member Jan 10, 2018 #4 You'll need to buy the DIP version of the 8M2 to fit into the 091 socket. The codes will be the same. You'll also need to provide a programming socket on your project board to program the already PCB mounted 08M2.
