Using restart/resume with multi task
69-cat
Question, I use this for triggering 10 watt LED strobes with a PIR for Halloween and noticed if I add another output "START5" the chip stops working. Is 4 the limit with this configuration?
Dave
[color=Navy]#Picaxe [/color][color=Black]14m2[/color]
[color=Blue]symbol [/color][color=Purple]PIR [/color][color=DarkCyan]= [/color][color=Purple]pinc.3[/color]
[color=Blue]symbol strobe1 [/color][color=DarkCyan]= [/color][color=Blue]B.1
symbol strobe2 [/color][color=DarkCyan]= [/color][color=Blue]B.2
symbol strobe3 [/color][color=DarkCyan]= [/color][color=Blue]B.3
symbol strobe4 [/color][color=DarkCyan]= [/color][color=Blue]B.4
pause [/color][color=Navy]45000             [/color][color=Green]'time for the PIR to settle [/color]
[color=Black]main:[/color]
[color=Blue]if [/color][color=Purple]PIR[/color][color=DarkCyan]=[/color][color=Navy]0 [/color][color=Blue]then [/color][color=Black]main[/color]
[color=Blue]resume [/color][color=Navy]1[/color]
[color=Blue]resume [/color][color=Navy]2[/color]
[color=Blue]resume [/color][color=Navy]3[/color]
[color=Blue]resume [/color][color=Navy]4[/color]
[color=Blue]Pause [/color][color=Navy]10000[/color]
[color=Blue]restart [/color][color=Navy]1[/color]
[color=Blue]restart [/color][color=Navy]2[/color]
[color=Blue]restart [/color][color=Navy]3[/color]
[color=Blue]restart [/color][color=Navy]4[/color]
[color=Blue]goto [/color][color=Black]main[/color]
[color=Blue]start1:
  low strobe1
  suspend [/color][color=Navy]1
  [/color][color=Blue]do
    high strobe1 [/color][color=Black]: [/color][color=Blue]pause [/color][color=Navy]25
    [/color][color=Blue]low  strobe1 [/color][color=Black]: [/color][color=Blue]pause [/color][color=Navy]65
  [/color][color=Blue]loop
start2:
  low strobe2
  suspend [/color][color=Navy]2
    high strobe2 [/color][color=Black]: [/color][color=Blue]pause [/color][color=Navy]30
    [/color][color=Blue]low  strobe2 [/color][color=Black]: [/color][color=Blue]pause [/color][color=Navy]55
start3:
  low strobe3
  suspend [/color][color=Navy]3
    high strobe3 [/color][color=Black]: [/color][color=Blue]pause [/color][color=Navy]25
    [/color][color=Blue]low  strobe3 [/color][color=Black]: [/color][color=Blue]pause [/color][color=Navy]60
start4:
  low strobe4
  suspend [/color][color=Navy]4
    high strobe4 [/color][color=Black]: [/color][color=Blue]pause [/color][color=Navy]30
    [/color][color=Blue]low  strobe4 [/color][color=Black]: [/color][color=Blue]pause [/color][color=Navy]50
  [/color][color=Blue]loop[/color]
Only the 08M2 and the original 18M2 are limited to 4 tasks (0 to 3).
The later 18M2+ and the 14M2 & 20M2 are capable of 8 tasks (0 to 7).
Start0 is implied as the first task at the first line of code if the label Start0 is not specifically included.
Currently Not at a PC to test but suggest you indicate which version of the Programming editor you are using.
Under 6.0.9.2 (6.0.9.3 is latest) the following passes syntax and will simulate correctly.
I reduced the duration of the two PAUSE comments in the main loop to make simulation faster.
Can you clarify if with PE V6.0.7.3 you could get the PE to pass on syntax and simulate correctly?
Is the problem limited to operation in an actual 14M2 chip?
#Picaxe 14m2
symbol PIR = pinc.3
symbol strobe1 = B.1
symbol strobe2 = B.2
symbol strobe3 = B.3
symbol strobe4 = B.4
symbol strobe5 = B.5
pause 1000 ; 45000             'time for the PIR to settle
if PIR=0 then main
resume 1
resume 2
resume 3
resume 4
resume 5
Pause 1000 ; 10000
restart 1
restart 2
restart 3
restart 4
restart 5
start1:
  low strobe1
  suspend 1
    high strobe1 : pause 25
    low  strobe1 : pause 65
start2:
  low strobe2
  suspend 2
    high strobe2 : pause 30
    low  strobe2 : pause 55
start3:
  low strobe3
  suspend 3
    high strobe3 : pause 25
    low  strobe3 : pause 60
start4:
  low strobe4
  suspend 4
    high strobe4 : pause 30
    low  strobe4 : pause 50
start5:
  low strobe5
  suspend 5
    high strobe5 : pause 30
    low  strobe5 : pause 50
I can't see any reason why the code wouldn't work just as well for six tasks as it does for five. It would be worth upgrading PICAXE Editor to the latest but I would doubt that is the issue.
Perhaps it's the addition of another set of strobes, or something about the strobe last added, which causes the problem. You could try only restarting task 5 to see if that works. It might be that in triggering all five sets of strobes that causes a PICAXE reset. You could add a SERTXD() at the start of the program to determine if that is happening or not.
69-cat
It looks like the version was the issue "so far" I have another bug that I see but would like to troubleshoot first. Myself, I like learning from my mistakes. I think that is the best way you learn how to solve problems. Thank you for bringing the version of the software to light, I never gave that a thought.....
Dave
