PE6 or the Simulator are usually the quickest way to answer such questions. Type
#SLOT 0 into the PE, hit the syntax check and it will respond "Compiled successfully. Memory Used = 3 out of 2048 bytes". Change that to
#SLOT 1 for the same result, but any other number gives the response "#slot - 20M2 only has slots 0 and 1!".
Each slot also has its own 512 bytes of TABLE memory, but AFAIK they share the 256 bytes of EEPROM/DATA and 512 bytes of RAM. Also, as I discovered
recently, there can be effectively rather more than 2048 Program bytes in each slot!
