​ ​ ​ ​ LCD simulation opened when simulating sertxd-message block
Results 1 to 5 of 5
Thread: LCD simulation opened when simulating sertxd-message block
  1. #1
    Join Date
    Apr 2011
    Location
    Spain
    Posts
    147
    Default LCD simulation opened when simulating sertxd-message block
    Hi
    If I try to simulate the block sertxd-message, a 16x2 LDC simulation is opened too.
    Why?
  2. #2
    Join Date
    Jan 1970
    Location
    UK
    Posts
    23,741
    Default
    The LCD simulation panel when enabled opens whenever there is a SERTXD or SEROUT command in the program, regardless of which pin that simulated LCD is connected to. This is the case for Basic, Flowchart and Blockly simulation.
    It is effectively 'turning on the LCD when the PICAXE is turned on' as simulation starts. To disable the LCD simply select it not to be simulated.
  3. #3
    Join Date
    Apr 2011
    Location
    Spain
    Posts
    147
    Default
    Thanks hippy
  4. #4
    Join Date
    Apr 2011
    Location
    Spain
    Posts
    147
    Default
    Hi again
    Is there a directive to enable/disable the LCD when simulating?
    If not, could it be added in future?
  5. #5
    Join Date
    Jan 1970
    Location
    UK
    Posts
    23,741
    Default
    There is no directive I know of at present but I would guess it could perhaps be added. Whether it would be is another question but I will log the suggestion for the development team.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
