PhilHornby
In the next phase of my project, I want to trigger two Triacs to control two 1KW heater elements. The elements are physically inter-connected and the centre point is currently used as the Neutral. The elements will be switched on either together, or separately for several minutes at a time.
I've never fully understood Triacs, and there seem to be different ways to connect them to the load. The following diagram shows the methods that seem the most common :-
Given that I have two Triacs, and two loads connected via their Neutrals, "Fig A" would seem to be the natural choice of configuration. However, since the opto-isolator will be triggered continuously for several minutes at a time, I am worried about the wattage rating of the resistor. (I can see that in "Fig C", when the Triac conducts it takes away the current flowing in the resistor - but I don't fully understand what happens in "Fig A" and "Fig B".)
If necessary, I can rewire the heaters so their common point is Live, rather than Neutral, but I'd prefer not to.
