​ ​ ​ ​ RC switch
Results 1 to 7 of 7
Thread: RC switch
  1. #1
    Join Date
    Jun 2012
    Location
    Netherlands
    Posts
    19
    Default RC switch
    For my model aircraft I needed a remote controlled switch for aircraft lighting, and other functions.
    The aircraft lights consist of 12V LED strips.
    This switch allows 2 groups of LED's to be controlled independent.
    The switch uses an 08M2 to convert the PWM RC input signal and drive the power switches.
    There are 2 jumpers in the circuit, that allow programming the switch detection levels (PWM level that turns on the particular switch).
    Installation:
    connect the circuit to the receiver channel (i.e. the GEAR switch)
    put JP1 on (if there is a LED strip attached, it will light up if 12V is connected)
    Turn on the receiver and transmitter in the required setting for this function.
    The 08M2 will (after 1 second) start measuring the PWM , and store it in internam memory.
    Repeat this for JP2 (remove JP1).
    Remove both JP1 and JP2. The circuit is ready for use.
    ' ------------------------------------- RC switch -------------------------------------
    ' Uses 1-2mSec RC PWM signal to trigger 2 power FET's to control auxilliary functions
    ' in an RC car, boat or airplane. Uses PICAXE 08M2
    ' OUTL and OUTR have pull down resistors (no accidental firing) and drive N channel
    ' power FET's. These can be controlled individually from the RC transmitter, for lighting,
    ' dropoff of sweets, or for launching rockets (fireworks).
    ' the software has 2 modes
    ' learning mode -----------------------------------------------------------------------------
    ' at powerup OUTL and OUTR serve as configuration pins. When one of these pins is
    ' connected to Vcc, then the software reads the PWM value from the RC receiver and
    ' stores it in EEprom. From now on it will use this value as a trigger for this switch channel.
    ' method: set controls at RC transmitter in correct setting for channel L. Set OUTL high (jumper).
    ' Now Power on RC receiver and RC switch. Wait 2 seconds (to learn PWM). switch off receiver
    ' and RC switch. Repeat procedure for channel R.
    ' please be aware that during learning mode the power FET's will be ON.
    ' operating mode ---------------------------------------------------------------------------
    ' in this mode the RC switch listens to the PWM signal from the RC receiver.
    ' When it receives a PWM that is withing +/- 20uSec in pulse width identical to the stored
    ' value in EEprom, it switches ON the associated power FET (and switches off the other one).
    ' in all other PWM values both FET's are off.
    ' 	     	PICAXE08M2
    '	       	+----_----+
    '	+5V        +1        8+         GND
    '	NC          +2        7+         NC
    '	POT    4  +3        6+   1    OUTL
    '	PWM   3  +4        5+   2    OUTR
    ' version control
    ' 0.1	pwmin, detect at fixed levels
    ' 0.2	jumpers on out1 and out2 used to program values in eeprom. no jumper = run
    '		potmeter is not being used anymore, but jumpers
    ' 0.3	jumpers inverted to prevent accidental firing during initialization with pull ups.
    '		lost 2 rockets because of this flaw....
    Init:
    	'set outputs OUTL and OUTR to INPUT mode to check if learning mode is required
    	input 1
    	input 2
    CheckMode:
    	'check if we need to calibrate, or execute
    	'the outputs are at this moment still inputs and pulled low (pulldown)
    	'unless config jumper to Vcc is placed
    	pause 250	     		    ' time to settle inputs this pause also
    							   ' minimizes EEprom writes by slowing
    							   ' the read PWM - write EEprom loop.
    	if pin1=1 then CalPinL	     ' OUTL is Vcc
    	if pin2=1 then CalPinR	    ' OUTR is Vcc
    	pause 250
    	low 1					' both FET's off
    	low 2
    	goto RunMode
    CalPinL:
    	pulsin C.3,1,w1       		' get pwm input for L
    	write 1,b2                   	    ' store value for L in mem 1 (b2 is low byte of w1)
    	goto CheckMode
    CalPinR:
    	pulsin C.3,1,w1       		' get pwm input for R
    	write 2,b2                   	    ' store value for R in mem 2 (b2 is low byte of w1)
    	goto CheckMode
    RunMode:
    	w1 = w1 + 2		  	 ' prepare for jitter window +2 / -2
    	b4 = 0
    	read 1, b1		   	    ' compare pwm to value for L with threshold +/- 2
    	b1 = w1 - b1
    	if b1 < 4 then
    		high 1			 	' on L
    		low 2		  		' off R
    		b4 = 1				' note we fire
    	end if
    	read 2, b1		   	     ' compare pwm to value for R with threshold +/- 2
    	b1 = w1 - b1
    	if b1 < 4 then
    		high 2				 ' on R
    		low 1		  		' off L
    	end if
    	if b4 = 0 then			' check if no fire trigger
    		low 1				' off L
    		low 2				' off R
    	end if
    	pause 100				' here we skip up to 5 PWM cycles, but not critical
    							  ' for the application
    	goto RunMode
    Attached are photo's of the prototype, and the circuit diagram.
    The power FET's can switch significant current, more than needed for LED strips, to also cover other applications.
  2. #2
    Join Date
    Jun 2012
    Location
    Netherlands
    Posts
    19
    Default Schematics added
    Schematics where skipped in upload.
    Another application for the RC switch (no explanation needed).
    Happy flying
  3. #3
    Join Date
    Apr 2013
    Location
    north dakota
    Posts
    334
    Blog Entries
    2
    Default
    Hi Volhout I don't mean to add garbage to your post but
    good job on the detail and pictures
    just would love to see a video of those rockets (i believe anyway) firing off in the last picture
    thanks for posting
    Mark
  4. #4
    Join Date
    Feb 2010
    Location
    Don't Mess With My Texas!
    Posts
    2,326
    Blog Entries
    5
    Default
    Volhout, how does the little pilot get out under the wing to light those rockets? Even more interesting would be the explanation on how he keeps the match lit while hanging from the wing.
    - Tex
    These words are my opinion, WYLION. Any resemblance to truth or fiction is accidental at best.
    "Truth lies dormant in our future history." ― Tex Clodhopper LXVI
    "Confidence is ignorance. If you're feeling cocky, it's because there's something you don't know." ― Eoin Colfer, Artemis Fowl
  5. #5
    Join Date
    Jun 2012
    Location
    Netherlands
    Posts
    19
    Default
    See movie, it was a foggy day.....
    https://drive.google.com/open?id=0B_...EwyNXZhaUZRUEE
    Short, but enjoy....
    The igniters (china import 50 pieces for 5 pounds).
  6. #6
    Join Date
    Mar 2014
    Location
    maryland
    Posts
    64
    Default
    When I was into flying RC many years ago I used the glow plugs with a 1.2 nicad to power it. Back then I used a servo with snap switches to trigger the glow plugs. I would place the rocket onto the tube under the wing and place the fuse into the glow plug and hope it would light off. Funny story, one time I did this in a dive and the wind pressure from the dive kept the rocket on the wing after it was lit, the rocket went off and put a small hole in the covering of the wing.....lesson learned!
    Dave
  7. #7
    Join Date
    Apr 2013
    Location
    north dakota
    Posts
    334
    Blog Entries
    2
    Default
    @ volhout that is cool now all you need is gps rockets with missile seeking heads and fly it over to north Korea and save the picaxe forum
    @69-cat that is neat never thought glow plugs would lite em with the wind an etc and love the switch setup
    @texasclod I think netherlands poeple are good at training gophers that smoke cigars
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
