afb
I have a word variable stored in eeprom 6 & 7 which in certain circumstances I need to reset with a fixed value, in my case 90. The statement "write 6, word 90" fails syntax check. Assigning 90 to a word variable, eg w0, and then issuing "write 6, word w0" is a work around, as is omitting the "word" qualifier and just altering the LSB and MSB in turn "write 6, 90: write 7, 0".
So I'm not stuck, but curious as to the correct syntax to perform this operation. This is for the 08M2 and I'm still using PE5 if that is relevant.
Alan
EDIT 1 hr later - ARRRGH ! ! ! - just having re-read the manual for the 20th time, this time I saw that the write syntax only accepts word variables as an argument when the qualifier "word" is used and equally I realise I could have said "write 6,90,0" as well - this is what comes of coding early in the morning before sufficient coffee has been consumed!
Alan
