newplumber
Hello
I have completed my stair led project and of course I will add more to it (still thinking about a lighted hand rail with a cool/horrible idea)
I will update this page when I have more information or need corrections
but here is the start of my finished stair project.
Thanks again for everyone here on all the help.
MATERIAL/PRICE LIST
Stair steps = 16_____free
2- reels of cool white apa102 led strips = $60 usd
4- 1"X12"X8' MDF boards = $100 usd
1- gallon of super gloss white paint = $34 usd
1- picaxe 20X2 chip from picaxe.com = $4 usd
2- 100 uf caps price NA ( I have all mine from auctions)
1- 10 uF cap price NA
1- .01 uF cap price NA
2- 300 ohm resistor price NA
1- 22k ohm resistor price NA
1- 10k ohm resistor price NA
1- 5 amp fuse+ holder price NA
1- PC power supply 5 volt 15 amp price $1.00 usd (older pc)
1- pcb board from Lbenson drawning to oshpark = $3 usd
4- weeks of learning from cool picaxe forums poeple = priceless
3- days for install..or 1 1/2 days without kids but we had fun
Total cost est = 250 usd
Total time est for me = 6 years 4.5 months
Total time for a pro = 2 hours 3.5 minutes
your always late for work friend
Mark
' CODE is for picaxe 20X2 and for two sets of white (no RGB) APA102 LED strips
' with two SR501 motion sensors for the top and bottom of stairs, picaxe wires to the led strips
' start at the bottom of the stairs.
'bottom sensor = B.0.....top sensor = B.1
#picaxe 20x2
#no_table
#no_data
setfreq m64
Let DIRSB = %10000000 : Let DIRSC = %00000010
; Set how many LED modules in the strip
symbol HOW_MANY_LEDS = 141 ;<-- how many leds you have to flow up/down on stairs (mine took 141)
; Set the brightness of the LED while testing
; Use small values to keep current consumption low
symbol brightLED = 180 ; 0 to 255 (full)
symbol dimLED = 10 ; 0 to 255 (full)
symbol Ptime = 200 ; pause time
; Initialise the HSPI interface
#macro init()
hspisetup spimode00, spimedium
#endmacro
; Send a four byte packet out via HSPI
#macro sendPacket( n1, n2, n3, n4 )
hspiout( n1, n2, n3, n4 )
#endmacro
; Send the start of data header
#macro head()
sendPacket( $00 ,$00 ,$00 ,$00 )
#endmacro
; Send a LED controlling command
#macro send( red, white, blue)
sendPacket( $FF, red, white, blue ) ' send packet ups or fedex you choose :)
#endmacro
; Send the end of data tail
#macro tail()
sendPacket( $00 ,$00 ,$00 ,$00 )'1-64
#endmacro
; Turn a single LED off
#macro ledOff
send( $00, $00, $00 )
#endmacro
; Turn LED on bright
#macro LEDbright
send( $00, $00,brightLED )
#endmacro
; Turn LED on dim
#macro LEDdim
send( $00, $00,dimLED )
#endmacro
PowerOnReset:
init
head
for b1 = 1 to HOW_MANY_LEDS ' makes all leds off
ledOff
next b1
tail
pause 2000
START:
gosub All_On_dim ; Turns all leds on dim
pause 200
DO : pause Ptime
IF pinb.0 = 1 then gosub LEDS_ON_FROM_BOTTOM ' check bottom sensor
IF pinb.1 = 1 then gosub LEDS_ON_FROM_TOP ' check top sensor
LOOP
LEDS_ON_FROM_BOTTOM:' flows leds UP on bright
FOR b1 = 1 to HOW_MANY_LEDS
head
FOR b2 = 1 to b1
LEDbright
NEXT b2
b3 = HOW_MANY_LEDS - b1
If b3 = 0 then PASS_LED_dim
FOR b2 = 1 to b3
LEDdim
NEXT b2
PASS_LED_dim:
tail
NEXT b1
STAY_ON_BRIGHT: W4 = 0
DO : Pause Ptime : inc W4
IF PINB.1 = 1 and PINB.0 = 0 then LEDS_OFF_FROM_BOTTOM 'if top sensor = 1 then turn leds back to dim
IF PINB.1 = 0 and PINB.0 = 1 then STAY_ON_BRIGHT 'if bottom sensor = 1 then keep leds bright
IF PINB.1 = 1 and PINB.0 = 1 then STAY_ON_BRIGHT 'if both sensors = 1 then keep leds bright
LOOP until W4 = 2 ' if both sensors = 0 then wait a while then turn to dim
LEDS_OFF_FROM_BOTTOM: ' flows leds UP on dim
head
FOR b2 = 1 to b1
LEDdim
NEXT b2
If b3 = 0 then PASS_LED_bright
FOR b2 = 1 to b3
LEDbright
NEXT b2
PASS_LED_bright:
tail
NEXT b1
RETURN
LEDS_ON_FROM_TOP:' flows leds DOWN on bright
FOR b1 = HOW_MANY_LEDS to 1 step -1
head
b5 = b1 -1
if b5 = 0 then skip_LEDdim
FOR b2 = b5 to 1 step -1
LEDdim
NEXT b2
skip_LEDdim:
b3 = 1 + HOW_MANY_LEDS - b1
FOR b2 = 1 to b3
LEDbright
NEXT b2
tail
NEXT b1
STAY_ON_BRIGHT1: W4 = 0
IF PINB.1 = 0 and PINB.0 = 1 then LEDS_OFF_FROM_TOP 'if bottom sensor = 1 then turn leds back to dim
IF PINB.1 = 0 and PINB.0 = 1 then STAY_ON_BRIGHT1 'if top sensor = 1 then keep leds bright
IF PINB.1 = 1 and PINB.0 = 1 then STAY_ON_BRIGHT1 'if both sensors = 1 then keep leds bright
LEDS_OFF_FROM_TOP:' flows leds DOWN on dim
head
b5 = b1 -1
if b5 = 0 then skip_LEDbright
LEDbright
NEXT b2
skip_LEDbright:
FOR b2 = 1 to b3
LEDdim
NEXT b2
tail
NEXT b1
RETURN
All_On_dim:
head
LEDdim
next b1
tail
RETURN
Mark
