Hi all,
Regarding the AXE027 3.5mm stereo-plug wiring, is it wired differently (from the 'normal' standard) for a reason?
If i rewired my plug so the shield outer is now Ground (0v) will it become an issue where the data pin *might* come into contact with the shield outer during insertion and damage the AXE027 internal chip-driver????
I was just about to convert my 3.5mm connectors to 'normal' wiring, where tip and ring can be TX/RX data, and shield is Ground (0v), but will i introduce a problem as mentioned above?
Thanks in advance.
Marty
Thanks in advance.
Marty
