How to define a new function when a button is pushed long. Can it be done?
tschrama
hi all,
On a 08M2 chip, I am searching for a way to make a button do something entirely different when that button is being hold for more than 1 sec. I want it to write something to the EEPROM, like a 'store' function.
When being pushed and released shortly it should carry out it's normal function (switch the next relay).
Can it be done?
Greetz,
Thijs
Welcome to the PICAXE forum.
You can probably do it the hard way by checking if the button is held and for how long, something like this -
Symbol BTN         = pinC.3
Symbol PUSHED      = 1
Symbol heldTimeout = w0
Symbol PAUSE_TIME  = 10                ; 10ms
Symbol TIMEOUT     = 1000 / PAUSE_TIME ; 1000ms / 1s
  If BTN Is PUSHED Then
    If heldTimeout > 0 Then
      Pause PAUSE_TIME
      heldTimeout = heldTimeout - 1
      If heldTimeout = 0 Then
        Gosub HeldForTimeoutPeriod
  Else
    heldTimeout = TIMEOUT
Or you could do all that by using the BUTTON command -
http://www.picaxe.com/BASIC-Commands/Digital-InputOutput/button
tschrama
Symbol BTN         = pinC.3
Symbol PUSHED      = 1
      Pause PAUSE_TIME
  Else
Thx for the welcome! :D
I did try to figure out how to do it with the 'button'command, but I cant see how I can do that. It seems the button command only enables to repeat a action. Going to study your code snippet now.. thx!
tschrama
Well I tried but I couldn't find an elegant way, I doubt mine is any better then your example. Any remarks are highly valued.
butn:		if pinC.3 = 1 then		'button is released
			if b3 = 20 then		'pressed > 1000ms
			    	write b2, b1  	'store programm in EEPROM
			else				'pressed < 1000ms
				b3 = b3+1		'increment pressed counter
		if pinC.3 = 0 then		'button is released
			if b3>0 then 		'pressed > 50ms
				if b3<20 then	'pressed < 1000ms
					b0 = b0+1	'increment preamp channel
					if b0>3 then	'if b0 overflows to 4
						b0=0		'set it to 0
					gosub setpreamp	'set the preamp relays
				b3 = 0		'reset pressed counter to 0
reywas
Here's how I do it:
[color=Blue]if button [/color][color=DarkCyan]= [/color][color=Black]pushed [/color][color=Blue]then                         [/color][color=Green];button pushed?
      [/color][color=Blue]pause [/color][color=Navy]10                                  [/color][color=Green];10mS debounce
      [/color][color=Purple]b1 [/color][color=DarkCyan]= [/color][color=Navy]0                                    [/color][color=Green];clear "time accumulator"
      [/color][color=Blue]do while button [/color][color=DarkCyan]= [/color][color=Black]pushed [/color][color=DarkCyan]and [/color][color=Purple]b1 [/color][color=DarkCyan]< [/color][color=Navy]10      [/color][color=Green];button still pushed and hold time < 1S
            [/color][color=Blue]inc [/color][color=Purple]b1
            [/color][color=Blue]pause [/color][color=Navy]100                           [/color][color=Green];100mS
      [/color][color=Blue]loop
      if [/color][color=Purple]b1 [/color][color=DarkCyan]< [/color][color=Navy]10 [/color][color=Blue]then                           [/color][color=Green];if button not held for 1 sec
            ;code
      [/color][color=Blue]else                                      [/color][color=Green];button pushed for 1 sec
            ;code
      [/color][color=Blue]endif
endif[/color]
wapo54001
I don't use the button command, I do this by resetting the timer to zero when the button is pushed, then measuring the timer when the button is released to determine which action to take. On a rotary encoder, I use the shaft press in three different ways -- immediate press and release, a one-to-three second press, and a greater than three second press. If you have a display, you could compress the timing a bit and simply release when the correct option displays on the screen or LCD display.
