Hi All
was just having a play too see if I could
make a simple on off timer with the minimum
came up with using 1 variable and peek and poke
it gives equal high low periods
thats my mornings play over with
regards
john
symbol cfon=8
symbol cfoff=9
in:
dirsB=%11111111
b12=0
inti:
poke cfon,0
poke cfoff,b12
peek cfoff,@bptr 'checks to see if b12 loaded
if @bptr>0 then
peek cfon,@bptr 'controlls select case value
select case @bptr
case< b12
high B.0
@bptr=@bptr+1 'count up
poke cfon,@bptr
case>=b12
low B.0
peek cfoff,@bptr
@bptr=@bptr-1
poke cfoff,@bptr 'count dwn
if @bptr=0 then
poke cfon,0'reset
poke cfoff,b12
end select
if pinD.7=1 then'just for simulation
b12=9
goto inti
regards
john
