Just wondering if I can get some help with this board I just received, it is a wireless ps2/ps3 controller serial receiver board. I thought it would be a simple as a serin command and then debug (in a loop) to work out what button spits out what value, but instead it just stops at the serin command and doesn't receive anything. A lack of any sort of pdf or txt file to show what is what doesn't help. This is the board in question:
www.icstation.com/wireless-joypad-serial-port-pinboard-adapter-board-p-11477.html
The controller seems to be connected correctly, there is a led that blinks when the controller is not connected, then is steady on when connected.
Any sort of advise you can give would be great.
Murray
Murray
