Hi All,
I was playing with an 08M2 recently, then it dawned on me that there's no external reset pin.
I intend to use the serial pins (C.0 & C.5) for a project (using up all 6 I/O lines)
If i program the chip with some code running on all 6 pins, *will* i still be able to program it later on?
I'm assuming the chip will need a power-cycle during the programming phase, and "sneak in" before my program begins. Correct????
Do i need to set a small delay at the beginning of my program to allow a wider window for the programmer to handshake and program my chip?
with thanx
Marty.
with thanx
Marty.
