Dear ones who helped me before.
I need to make a litle moviclip of something that is hard to do out of hand. I need to do 3 clips +- exactly the same track so that it can be set on top of each other to form the endresult
Therefore I toaught of a linefolowing carage whereon the trypod with a camera would stand.
The carage would follow the line every time again and therefore make a reasonable same track.
So, I want to use 2 steppermotors that will drive the wheels and then a trailer wheel to keep everything in ballance.
I have no problem making the platform with the drive and al that is needed to do the job. The platform is like 1.1m triangular. So there is more than enough space for controle material.
The speed of the camera move will be 1meter / 3 to 6 seconds. the track is ALLMOST straigt
I read alot about line following robots, but all of them are small. I could not find one with steppermotors. I am planning to use size 23 ungeared motors because I have the at hand. I plan to use belts to drive the wheels.
Now is there anibody that knows of sutch a design, preferably with a picaxe?
Thank you,
Willy.
Blgium
I
Thank you,
Willy.
Blgium
I
