Hello
I am having some problems with Touch16 command on an 08M2 chip. I am using all the pins on the chip including pin c.5 as a digital input from an external switch. (I use the Disconnect command after the program starts to ensure pin c.5 works correctly). If the external switch is open and pin c.5 is held low by the 10k resistor then the Touch16 command works OK. However, if the external switch is closed and pin c.5 input is high then the Touch16 command stops working. I have tried connecting the touch sensor to all the other touch pins on the chip but the same problem occurs. The manual does refer to problems using a long serial download cable - am I experiencing the same issue with a digital input??
