Data Logger Data ?
TYKE
Ive started using the data logger and I'm having some problems with the down loaded data. When I run a mission even though it downloads the total number of data readings it only shows some of the first readings as a graph and if I export the file it does the same. For an example an overnight set of 147 readings showed only 71 of them on the graph ?
johnlong
Hi Tyke
can you supply the forum with more information the code that is causing the issue
and any circuit information you have
regards
john
TYKE
The logger is a AXE 110p Picaxe 18m2 data logger and the code is created automatically in the Picaxe editor from the data logger wizard menu.
Can you:
1. Post the code created by the PE wizard
2. Post the file with the downloaded data (in csv format?)
As you using PE ver5 or PE ver6 ?
TYKE
Sorry for the late reply but blame it on the holidays, the Editor version is 6.0.9.2
Ive also tried to post the csv file but it wont allow me to?
TYKE
I cant up load the csv file so here it is in long hand. Out of 30 results only 18 were shown on the graph.
0 184 19
1 238 19
2 238 19
3 238 19
4 238 20
5 238 20
6 238 20
7 238 20
8 238 20
9 238 20
10 238 20
11 238 20
12 238 20
13 238 20
14 238 20
15 238 20
16 238 21
17 238 21
18 237 21
19 237 21
20 237 21
21 237 21
22 237 21
23 237 21
24 237 21
25 237 21
26 237 21
27 237 21
28 237 21
29 237 21
30 237 21
31 237 21
32 237 21
33 237 21
