​ ​ ​ ​ Picaxe control of Adafruit 14 segment display with I2C backpack
Results 1 to 2 of 2
Thread: Picaxe control of Adafruit 14 segment display with I2C backpack
  1. #1
    Join Date
    Nov 2012
    Location
    London
    Posts
    264
    Default Picaxe control of Adafruit 14 segment display with I2C backpack
    Adafruit sell some nice 4x14-segment displays with an I2C backpack based on the Holtek HT16K33 driver chip. This thread discussed using the same backpack with a 4x7-segment display and I posted another code snippet for controlling an 8x8 LED matrix. The code snippet below shows how to control the 4x14-segment display so that you can show all the letters of the alphabet (upper case are good, lower case not quite so convincing) as well as numbers and some additional characters like + - / \. Connections are the same as the other backpack except that there is an additional "Vi2c" pin to connect to the processor's logic level. So, you could power the LED segments at 5v and the processor at 3.3V. In my case, I just powered both from a 4.5V battery pack.
    The module is initialised in the same way as with the other Adafruit devices. Then, to display characters you need to send the starting address 0x00, followed by four two-byte pairs (one pair for each "digit", working from left to right). The first byte for each digit is essentially the traditional 7-segment bit pattern (except that the middle segment is split into two). The second byte consists of the extra segments (e.g. the diagonal ones) needed to form the letters of the alphabet. Then you send the control byte $81 to "latch" the data to the display. As with the other backpack devices, control characters are available to dim and flash the display.
    I am posting this code to save people the chore of working out which bytes to send for each of the 60-plus displayable characters.
    #picaxe 08m2			' Define PICAXE 08M2
    #no_data				' Ignore EEPROM data - loads program faster
    SYMBOL countn=b0              ' make symbol for loop counter
    Initialize:				' Initialise pins and set up variables
    LET dirsC = %00000110		' Make pins C.1 & C.2 outputs; rest as inputs
    LET pinsC = %00000000 		' Turn off all outputs on port C
    Hi2cSETUP  i2cmaster,%11100000, i2cfast, i2cbyte ' initialise I2C device at $7E (converted to 8 bit address)
    PAUSE 1 ; wait 1 ms for the display chip to initialise
    Hi2cOUT ($21) ; start clock/oscillator
    ' data for each character
    '   byte1,byte2
    '0 = $3f,$0
    '1 = $6,$0
    '2 = $db,$0
    '3 = $cf,$0
    '4 = $e6,$0
    '5 = $ed,$0
    '6 = $fd,$0
    '7 = $1,$c
    '8 = $ff,$0
    '9 = $c7,$8
    '. = $0,$40
    '+ = $c0,$12
    '- = $c0,$0
    '/ = $0,$c
    '| = $0,$10
    '\ = $0,$21
    '$ = $8d,$c
    'all segments = $3f,$3f
    'A $F7,$0
    'B $8F,$12
    'C $39,$0
    'D $F,$12
    'E $F9,$0
    'F $F1,$0
    'G $BD,$0
    'H $F6,$0
    'I $9,$12
    'J $1E,$0
    'K $70,$24
    'L $38,$0
    'M $36,$5
    'N $36,$21
    'O $3F,$0
    'P $F3,$0
    'Q $3F,$20
    'R $F3,$20
    'S $ED,$0
    'T $0,$12
    'U $3E,$0
    'V $30,$C
    'W $36,$28
    'X $0,$2D
    'Y $0,$15
    'Z $9,$C
    'a $58,$10
    'b $78,$20
    'c $D8,$0
    'd $8E,$8
    'e $58,$8
    'f $71,$0
    'g $8E,$4
    'h $70,$10
    'i $0,$10
    'j $E,$0
    'k $0,$36
    'l $30,$0
    'm $D4,$10
    'n $50,$10
    'o $DC,$0
    'p $70,$1
    'q $86,$4
    'r $50,$0
    's $88,$20
    't $78,$0
    'u $1C,$0
    'v $4,$20
    'w $14,$28
    'x $C0,$28
    'y $C,$28
    'z $48,$8
    top:
    countn=0
    Hi2cOUT ($80) ; clear the display
    ' print out the character set four at a time
    '0 1 2 3
    Hi2cOUT $00,($3f,$0,$6,$0,$db,$0,$cf,$0)
    Hi2cOUT ($81) ; latch data to display
    '4 5 6 7
    Hi2cOUT $00,($e6,$0,$ed,$0,$fd,$0,$1,$c)
    '8 9 $ all
    Hi2cOUT $00,($ff,$0,$e7,$0,$ed,$12,$3f,$3f)
    Hi2cOUT $00,($0,$40,$c0,$12,$c0,$0,$0,$c)
    'A B C D
    Hi2cOUT $00,($F7,$0,$8F,$12,$39,$0,$F,$12)
    'E F G H
    Hi2cOUT $00,($F9,$0,$F1,$0,$BD,$0,$F6,$0)
    'I J K L
    Hi2cOUT $00,($9,$12,$1E,$0,$70,$24,$38,$0)
    'M N O P
    Hi2cOUT $00,($36,$5,$36,$21,$3F,$0,$F3,$0)
    'Q R S T
    Hi2cOUT $00,($3F,$20,$F3,$20,$ED,$0,$1,$12)
    'U V W X
    Hi2cOUT $00,($3E,$0,$30,$C,$36,$28,$0,$2D)
    'Y Z all all
    Hi2cOUT $00,($0,$15,$9,$C,$3f,$3f,$3f,$3f)
    'a b c d
    Hi2cOUT $00,($58,$10,$78,$20,$D8,$0,$8E,$8)
    'e f g h
    Hi2cOUT $00,($58,$8,$71,$0,$8E,$4,$70,$10)
    'i j k l
    Hi2cOUT $00,($0,$10,$E,$0,$0,$36,$30,$0)
    'm n o p
    Hi2cOUT $00,($D4,$10,$50,$10,$DC,$0,$70,$1)
    'q r s t
    Hi2cOUT $00,($86,$4,$50,$0,$88,$20,$78,$0)
    'u v w x
    Hi2cOUT $00,($1C,$0,$4,$20,$14,$28,$C0,$28)
    'y z
    Hi2cOUT $00,($C,$20,$48,$8,$0,$0,$0,$0)
    ' write some text
    ' 8 bytes - 2 bytes per digit
    '               L  |   O  |   V  |   E
    Hi2cOUT $00,($38,$0,$3f,$0,$30,$C,$f9,$0)
    '               B   |    E  |   E   |   R
    Hi2cOUT $00,($8F,$12,$f9,$00,$f9,$00,$f3,$20)
    Hi2cOUT ($E0) 'dim the display (range $E0 to $EF)
    Hi2cOUT ($EF) ' full brightness again
    Hi2cOUT ($83) 'blink the display ($83=2Hz blink, $85=1Hz, $87=0.5Hz)
    pause 3000
    ' make a spinney-round thing!
    do while countn<21
    	Hi2cOUT $00,($0,$12,$0,$12,$0,$12,$0,$12)
    	pause 20
    	Hi2cOUT $00,($0,$c,$0,$c,$0,$c,$0,$c)
    	pause 20
    	Hi2cOUT $00,($c0,$0,$c0,$0,$c0,$0,$c0,$0)
    	pause 20
    	Hi2cOUT $00,($0,$21,$0,$21,$0,$21,$0,$21)
    	pause 20
    	countn=countn+1
    loop 'till count=20
    loop 'back to top:
    Last edited by stevesmythe; 05-04-2017 at 20:00. Reason: Added codes for lower case letters
  2. #2
    Join Date
    Feb 2010
    Location
    Don't Mess With My Texas!
    Posts
    2,330
    Blog Entries
    5
    Default
    That's mighty nice of you to do that. Thanks!
    - Tex
    These words are my opinion, WYLION. Any resemblance to truth or fiction is accidental at best.
    "Truth lies dormant in our future history." ― Tex Clodhopper LXVI
    "Confidence is ignorance. If you're feeling cocky, it's because there's something you don't know." ― Eoin Colfer, Artemis Fowl
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
