Terminal t4800
Maco33
Hi guys, is there any software terminal that can display the communication mode T4800?
I mean showing communication between PICAXE and ESP8266.
M.
nekomatic
You mean you want to 'listen in' on this communication by connecting a computer to it? Any terminal program should be able to handle 4800 bps. To correctly interpret data with 'T' polarity you need to connect via a non-inverting USB-serial adapter - often referred to as a 'TTL level' adapter - rather than a USB-RS232 adapter which inverts the signals.
If you only have an actual RS232 serial port available, you'll need to invert the signal electrically - you could use a MAX232 type driver chip, but for purposes of testing a simple transistor and two resistors would probably do the job.
Jeremy Harris
I've used an FTDI USB to serial board to just "sniff" serial data being exchanged between a Picaxe and other modules, like the VDrive2 or the HC-12 transceivers, a few times now. Always seems to work reliably for any "T" (true) Picaxe baud rates.
I normally use PuTTY on Linux, or Termite on Windows, as the terminal emulators. Often it's useful to have both the Programme Editor terminal window open, listening to the Picaxe serial port and displaying debug info (I often use sertxd to transmit data from check points in the programme when de-bugging, rather than debug), and a separate terminal emulator on another port monitoring serial comms between the Picaxe and an external device. Recently it was how I discovered what was really going on with a Picaxe to VDrive2 interface, having previously had problems getting that to work reliably.
tmfkam
I made myself a simple serial LCD monitor, This has a PicAxe that has an input pin that is connected (in parallel) to the serial line I'm trying to monitor which simply reads in all serial data present and then echo's it to an LCD display. I've found it invaluable for diagnosing problems with serial communications as it gives me an idea as to whether any messages are being incorrectly transmitted, or incorrectly interpreted.
I naturally have to compile the serial monitor with the (intended) serial protocol before using it and then I can see what is going on. I most recently used it for attempting to interpret the returned messages from the DfPlayer MP3 player module when I was trying to query the track count on the disk.
The code is dual purpose, if 'Stand Alone' is defined it will display the baud value and wait for the first serial data to be received before the display is cleared and received data displayed, this is the mode used as a serial monitor. If 'Built In' is defined, the unit simply waits for data (the baud rate is not displayed when started).
The code is almost entirely the work of Ron Hackett, and I have only made some minor alterations. I can't recommend Ron's 'PicAxe projects' book enough, nor his 'PicAxe Primer' articles from Nuts and Volts magazine, I found them very informative and inspirational. I've been inspired to build a few of his little interface suggestions, the little vero-board programming interface for PicAxe programming is the work of a genius.
This code was lifted from a project I did that calculated and displayed energy created from a pedal powered generator in Volts, Amps, Watts and averaged Watt/Hours. Hence the custom icons for battery A/W and so on.
' *** LCD16x2-CustCharDriver14M2.bas ******************* 2011.10.01 ***
' This program runs on a Picaxe-14M2 @ 8MHz. It receives serial data
' from a master processor & diplays it on an HD 44780-type 16x2 LCD.
' *** Constants *******
  symbol  cmnd =      0       ' RSbit = 0 (low) for command bytes
  symbol  text =      1       ' RSbit = 1 (high) for text bytes
  symbol enPin =    B.1       ' LCD enable pin on B.1
  symbol rxPin =    C.4       ' serial data received on C.4
  Symbol BaudRate = N4800_32
' *** Variables *******
  symbol  char =     b0       ' character to be sent to LCD
  symbol index =     b1       ' used in for/next loop
  symbol nibHi =     b2       ' the high nibble of char
  symbol nibLo =     b3       ' the low nibble of char
  symbol RSbit =     b4       ' used to set up for cmnd/text byte
  symbol  temp =     b5       ' used to manipulate character data
  symbol RSpin = pinB.0       ' here, we're using RSpin as a variable
                              ' (to access the state of the input),
                              ' so the form "pinB.0" is required
  symbol Started=b27
' *** Directives ******
  #picaxe 14M2                ' set compiler mode
  #terminal off
  #Define StandAlone
  '#Define BuiltIn
' *** Data ************
; A
; W
  data (%00100) '  *
  data (%01010) ' * *
  data (%01110) ' ***
  data (%01010) ' * *
  data (%00000) '
  data (%10101) '* * *
  data (%11111) '* * *
  data (%01010) ' * *
  data (%00100) '  *
  data (%01010) ' * *
  data (%10001) '*   *
  data (%00100) '  *
  data (%00100) '  *
  data (%10001) '*   *
  data (%01010) ' * *
  data (%00100) '  *
  data (%00000) '
  data (%00000) '
  data (%00000) '
  data (%00000) '
  data (%00000) '
  data (%01110) ' ***
  data (%01110) ' ***
  data (%00000) '
; Batt Full
  data (%01110) ' ***
  data (%11111) '*****
; Batt Half
  data (%01110) ' ***
  data (%10001) '*   *
  data (%10001) '*   *
  data (%10001) '*   *
; Batt Empty
  data (%01110) ' ***
  data (%10001) '*   *
  data (%10001) '*   *
  data (%10001) '*   *
  data (%10001) '*   *
  data (%10001) '*   *
  data (%10001) '*   *
' Display on LCD
  data 48,("Serial LCD  V1.4")
  data 64,("Ready.Baud N4800")
' *** Begin Main Program **********************************************
  setfreq m32
  Symbol LCD_power=C.0
  high LCD_Power
  dirsB = %11111111           ' all PortB pins are outputs to the LCD
  dirsC = %11000111           ' C.3, C.4, and C.5 are fixed as inputs.
' *** Initialize the LCD ***
  outpinsB = 0                ' clear all output lines
  pause 1600                  ' pause 200 mS for LCD initialization
  outpinsB = 12               ' (48/4=12) set to 4-bit operation
  pulsout enPin,8             ' send data
  pause 80                    ' pause 10 mS
  pulsout enPin,8             ' send again
  pulsout enPin,8             ' send again (necessary in 4-bit mode)
  outpinsB = 8       	      ' (32/4=8) set to 4-bit operation
  pulsout enPin,8             ' send data.
  outpinsB = 32               ' (128/4=32) set to 2 line operation
  char  = 12                  ' display on, cursor off
  gosub OutToLCD
' *** Load custom chars into CGRAM ***
  char  = 64                  ' define custom characters
  RSbit = cmnd
  gosub OutToLCD2
  RSbit = text
  for index = 0 to 47         ' install 8 custom characters
    read index, char
    gosub OutToLCD2
  next index
  char = 1                    ' instruction: clear display
  gosub OutToLCD              ' send instruction to LCD
  pause 16                    ' minimum 2mS delay for clear display
#IfDef StandAlone Then
  char = 128                  ' instruction: go to start of 1st row
  for index = 48 to 63        ' output data to 1st row of LCD
    read index, char          ' read character from EEPROM
    gosub OutToLCD            ' send character to LCD
  next index
  Pause 16
   char = 192                 ' instruction: go to start of 2nd row
  for index = 64 to 79        ' output data to 2nd row of LCD
  next index
#EndIf
  Let Started=0
' *** Main loop: Receive data and display it. ***
  bptr = 28
  serin rxPin,BaudRate,@bptrinc
  serin [800], RxPin, BaudRate, @bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc
	  If Started=0 Then
	   Let char = 1
	  	gosub OutToLCD
	  	pause 16
	  	Let Started=1
	  EndIf
#EndIf
  @bptr = 0
  bptr = 28        ' Reset the byte pointer to the first location.
  do until @bptr = 0
    char = @bptrinc
    gosub OutToLCD
  loop                        ' do loop
loop                          ' main loop
OutToLCD:
  select case char
    case 0 to 31
      RSbit = cmnd
    case 128 to 207
      RSbit = cmnd
    case 123
      char  = 0					; W/H icon
      RSbit = text
   case 124
      char  = 1					; <> icon
      RSbit = text
    case 125
      char  = 2					; 'dp' icon
      RSbit = text
    case 208
      char  = 3					; Battery icon
      RSbit = text
    case 209
      char  = 4					; Battery Half icon
      RSbit = text
     case 210
      char  = 5					; Battery Empty icon
      RSbit = texte
    case 255						; Reset LCD Display
    	Low LCD_Power
    	Reset
      RSbit = text
  endselect
OutToLCD2:
  nibHi = char & %11110000    ' isolate high nibble of char
  nibHi = nibHi / 4           ' move to pins 5,4 ,3 & 2
  outpinsB = nibHi            ' place high nibble of char onto pins
  RSpin = RSbit               ' RSpin = 0 for cmnd or 1 for text
  pulsout enPin,2            ' send data
  nibLo = char & %00001111    ' isolate low nibble of char
  nibLo = nibLo * 4           ' move to pins 5,4 ,3 & 2
  outpinsB = nibLo            ' place low nibble of char onto pins
	#IfDef BuiltIn Then
		#Error "Stand alone and Built in both defined."
	#EndIf
#Else
	#IfDef BuiltIn Then
		Let Char=0
	#Else
		#Error "Stand alone or Built in must be defined."
	#EndIf
#EndIf
As I say, I've found it very useful, and more convenient than a PC terminal.
tmfkam
This a modified version that uses a 20x2 (SPI?) VFD display to display hex values transmitted serially. The hex conversion was lifted from a post made by Hippy on this forum. The rest of the code is very similar to (I.E. copied from!) some VFD control demo software here on the forum, originally posted by MkStevo.
This waits for a qualifier of 7E which is part of the command structure for the DfPlayer MP3 module which is what I most recently used this for.
#picaxe 08M2
#Define StandAlone
Setfreq M32
Symbol stb = C.4
Symbol sck = C.1
Symbol sda = C.2
Symbol sda_pin = pinC.2
Symbol rxpin =    C.3       ' serial data received on C.3
'Symbol BaudRate = N4800_32
Symbol baudrate = T9600_32
Symbol timing = 1
Symbol char1=17
Symbol raw=b0
Symbol chrs=b1
Symbol cmd=b2
Symbol dataposition=b3
Symbol displayposition=b4
Symbol index=b5
Symbol Started=b6
Symbol var1=b7 'Hexadecimal conversion
Symbol var2=b8
Symbol var3=b9
Output sda
Gosub Clear_Disp
Gosub Disp_On
Let chrs=char1
Let displayposition=0
	'Display on VFD
	Data 0, ("Serial Data  Monitor")
	Data 20,("T9600.8 Qualifier=7E")
	'Data 41,("Test  Mode  Selected")
	Pause 100
	For index = 0 To 19        ' output data to 1st row of VFD
		Read index, chrs        ' read character from EEPROM
		Gosub Check_Chrs         ' send character to VFD
	Next index
	Let cmd=168						;Line 2, position 1
	Gosub Send_Function
	For index = 20 To 40       ' output data to 2nd row of VFD
	Next index
Main:
		Do
			bptr = 28							'Set up to begin storing data at location 29,
													'(just above the 28 general purpose variables)
			Serin RxPin, baudrate, @bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc,@bptrinc
			@bptr = 0				'We're using 0 as an end of transmission marker.
			If Started=0 Then
				Let Started=1
				Gosub Clear_Disp
			EndIf
			Let cmd=128					;Line 1, position 1
			Gosub Send_Function
			bptr = 28				'Reset the byte pointer to the first location.
			'Send two spaces to centralise the display
			Let chrs=32
			Gosub Send_Char
			Let chrs=32
			Gosub Send_Char
			Do Until @bptr = 0	'loop until we reach the EOT character
				chrs = @bptrinc	'get each byte
      		Let var1=chrs
				Gosub HexToAscii
				Let chrs=var1
				Gosub Send_Char
				Let chrs=var2
				Gosub Send_Char
				'Let chrs=32
				'Gosub Send_Char
			Loop						'do loop
			Let chrs=32
			Gosub Send_Char
			Let chrs=32
			Gosub Send_Char
		Loop
Goto Main								'main loop
Send_Data:
	High sck
	High stb
	Pause timing
	Low stb
	Let raw=250					;Data Send
	Gosub Send_Raw_Reverse
Return
Send_Ins:
	High sck
	High stb
	Pause timing
	Low stb
	Let raw=248					;Instruction Send
Return
Clear_Disp:
	Gosub Send_Ins
	Let raw=1					;Display Clear
	Pause 10
Return
Disp_On:
	Gosub Send_Ins
	Let raw=12					;Display on
Return
Send_Char:
	Gosub Send_Data
	Let raw=chrs				;Character value
Return
Send_Function:
	Gosub Send_Ins
	Let raw=32					;Function Set
	Gosub Send_Ins
	Let raw=cmd					;Command to send
Return
Send_Raw_Reverse:
	Pause timing
	Low sck
	Let sda_pin=bit7		'Character stored in Raw
	Pause timing
	High sck
	Pause timing
	Low sck
	Let sda_pin=bit6
	Pause timing
	High sck
	Pause timing
	Low sck
	Let sda_pin=bit5
	Pause timing
	High sck
	Pause timing
	Low sck
	Let sda_pin=bit4
	Pause timing
	High sck
	Pause timing
	Low sck
	Let sda_pin=bit3
	Pause timing
	High sck
	Pause timing
	Low sck
	Let sda_pin=bit2
	Pause timing
	High sck
	Pause timing
	Low sck
	Let sda_pin=bit1
	Pause timing
	High sck
	Pause timing
	Low sck
	Let sda_pin=bit0
	High sck
	Pause timing
	Low sck
Return
Check_Chrs:
	Select Case chrs
		Case 1
			Gosub Send_Function
		Case 2
			Gosub Send_Function
		Case 3
			Gosub Clear_Disp
		Else                      ' all other text
      	Gosub Send_Char
	EndSelect
Return
HexToAscii:
	'converts var1 byte variable to 2 ASCII hex characters, ascii characters returned in var1 and var2
	var2 = var1 And $0F 			'isolate bottom nibble
	If var2 < 10 Then
		var2 = $30 + var2
	Else
		var2 = var2 + 55
	var3 = var1 And  $F0 			'isolate top nibble
	var3 = var3 / 16				'moves top 4 bits into bottom 4 bits
	If var3 < 10 Then
		var3 = $30 + var3
	Else
		var3 = var3 + 55
	var1 = var3
Return
