PhilHornby
Demonstration / Test program for HTU21D Humidity / Temperature sensor (V2)
HTU21D Humidity / Temperature Sensor Demonstration / Test Program
There are several threads in the forum regarding this sensor - this seeks to expand on the information found therein.
See: http://www.picaxeforum.co.uk/showthread.php?26344-Integrating-HTU21D-temperature-humidity-sensor-using-I2c-using-18m2/page2
and http://www.picaxeforum.co.uk/showthread.php?26354-HTU21D-Maths-question
Manufacturer's datasheets:-
(Main) http://www.amsys.info/sheets/amsys.en.htu21d.pdf and (Serial no. information) http://www.amsys.info/sheets/amsys_fan001.pdf
The attached code was developed on a Picaxe 20X2 (running @ 3V to match the HTU21D). It contains some 20X2-specific features (I²C SFR references and Picaxe-basic instructions). The minimum circuit is simply the 20X2 connected to the HTU21D via the I²C bus wires (SDA/SCL). I used a ready-made module containing the HTU21D and the I²C pull-up resistors. The resistors needed to be connected via pads on the module. I have also included the schematic for running the Picaxe @ 5V, with the HTU21D at its maximum of 3.3V. In this case, the SCL/SDA pull-up resistors must be connected to the 3.3V line NOT the 5V line.
The program demonstrates the following features (in addition to retrieving basic Humidity / Temperature readings) :-
Sample output :-
- R.H. compensated for temperature, when readings are in the range 0º to 80ºC.
- Diagnostic Heater operation. This is turned on for 30 seconds when the program starts, so you should see the readings fall back towards ambient, over a period of 5 minutes or so.
- Unique Serial Number decoding.
- Testing for the device presence on the I²C bus.
- PSU status (as monitored by the HTU21D)
- CRC checking of the received data. In tests, CRC errors have been very, very rare - but they have occurred.
Sample output :-
HTU21D - Diagnostic / Demo
HTU21D Serial = 0x48540053F7B33211
Heater turned ON for 30 secs. Please wait
Heater turned OFF, monitoring
Temperature: 25.0c Humidity: 33% adj. -0.000% Comp. Humidity: 33%
Temperature: 23.3c Humidity: 37% adj. -0.255% Comp. Humidity: 37%
Temperature: 23.0c Humidity: 37% adj. -0.300% Comp. Humidity: 37%
Temperature: 22.9c Humidity: 38% adj. -0.315% Comp. Humidity: 38%
Temperature: 22.8c Humidity: 38% adj. -0.330% Comp. Humidity: 38%
Temperature: 22.7c Humidity: 38% adj. -0.345% Comp. Humidity: 38%
Temperature: 22.6c Humidity: 38% adj. -0.360% Comp. Humidity: 38%
