Pop-Up messages when developing code for AXE401
While developing code for the AXE401, I'm getting random pop-up messages like the attached. The code passes a syntax check and loads and runs correctly in the real PICAXE (28X2, obviously).
PE v6.0.9.1. The problem also occurs in older versions of the PE. I suspect that the lookup data for PICAXE shield pin notations for some background task (real-time syntax checking?) is missing a few definitions.
IWP, I had the same "problem" a couple of years ago on a project, but don't remember if I reported it or not. Didn't seem to cause me any trouble, but was a bit disconcerting.
Thanks for the report, this is a bug where the simulator engine is being passed the pseudo shield variable name pinS.x instead of the real variable name pinC.x
We will fix for next release.
