Macro Problem With Serin Timeout
techElder
Well-known member
I can't find a way to get around the compiler message "Duplicate label name - timeoutLabel" with SERIN using a timeout label in a #Macro definition.
#Macro mySerMacro
serin [timeoutTime, timeoutLabel],pin,baud,variable
' do something
goto nothingHappened
timeoutLabel:
' do something different
goto exitThisRoutine
nothingHappened:
exitThisRoutine:
#endm
BESQUEUT
#Macro mySerMacro
' do something
timeoutLabel:
nothingHappened:
exitThisRoutine:
#endm
Maybe something like :
[color=Navy]#Macro [/color][color=Black]mySerMacro
      [/color][color=Blue]gosub [/color][color=Black]DoSerial[/color]
[color=Navy]#endmacro[/color]
[color=Black]DoSerial:
      [/color][color=Blue]serin [PLAIN][[/PLAIN][/color][color=Black]timeoutTime, timeoutLabel[/color][color=Blue][PLAIN]][/PLAIN][/color][color=Black],pin,baud,variable
      [/color][color=Green]' do something[/color]
[color=Blue]return[/color]
[color=Black]timeoutLabel:
      [/color][color=Green]' do something different[/color]
But why do you want to use a macro ?
techElder
Well-known member
I know how to do it, but wanted to explore the limits of #Macro.
I believe this is a compiler situation where it could be handled differently.
BESQUEUT
#macro is not a command ; this is not related to compiler.
#macro is another way to write inline code. So of course, you cannot use a LABEL (more that once) within a macro.
Goeytex
Of course.
Since a macro is inserted inline that would create 2 labels named "TimeOutLabel". Thus the duplicate label error.
The TimeOutLabel must be outside of the Macro. That would apply to all labels. None inside of a macro.
You can pass label names into a #MACRO ...
#Macro SerInTimeout( timeoutLabel, exitLabel )
  serin [1000, timeoutLabel], C.0, N2400, b0
    SerTxd ( "Got it" )
    goto exitlabel
  timeoutLabel:
    SerTxd( "Timed out" )
  exitLabel:
#EndMacro
SerInTimeout( L1, L2 )
SerInTimeout( L3, L4 )
You can also pass in labels defined outside the #MACRO ...
    SerTxd ( "Got it" )
    goto exitlabel
  timeoutLabel:
#EndMacro
MainLoop:
  Do
    SerInTimeout( L1, MainLoop )
    SerInTimeout( L2, MainLoop )
  Loop
techElder
Well-known member
I used the word "compiler" because that is when the situation arises. Syntax checks didn't find this situation.
Testing didn't show this situation until I used the macro more than once in a program. I see that now. The second time I used the macro, the duplicate label was created.
Passing the label as a parameter is tedious at best. Guess I'll keep it as a subroutine. At least I can call it with a macro. ( BESQUEUT, because that's the way I'm doing this project.)
Thanks for showing me the problem (me!), guys, and Hippy showed me a new trick! :D
