​ ​ ​ ​ Picaxe control of Adafruit 8x8 LED matrix with i2c backpack
Results 1 to 5 of 5
Thread: Picaxe control of Adafruit 8x8 LED matrix with i2c backpack
  1. #1
    Join Date
    Nov 2012
    Location
    London
    Posts
    271
    Default Picaxe control of Adafruit 8x8 LED matrix with i2c backpack
    I couldn't find any Picaxe Basic code examples for controlling this display, but this thread described how to control a 4-digit, 7-segment display that uses the same backpack.
    Building on the information in that thread, I have produced the following code that demonstrates how to turn on/off, dim or flash the display and control which pixels are lit up. By giving it its own thread, people searching on the Internet for information on how to control this module (as opposed to the 7-seg version) will find it more easily.
    1. After initialising, the starting address ($00) is sent, then (in brackets in the example below), the string of data containing the value for each of the 8 columns, where the "value" is the row value in binary, MSB first. However, the row value is a 16 bit value and only the first 8 bits are physically connected. So, every other byte is ignored. I have put $AA into each of these in the example below, just so they are not confused with anything else.
    2. For some reason, the physical row 0 (at the top if you look at the display with the Adafruit logo at the bottom) is wired as the MSB so all the other rows are shifted down.
    picaxe 08m2	' Define PICAXE 08M2
    #no_data		' Ignore EEPROM data - loads program faster
    Initialise:				' Initialise pins and set up variables
    LET dirsC = %00000110		' Make pins C.1 & C.2 outputs; rest as inputs
    LET pinsC = %00000000 		' Turn off all outputs on port C
    Hi2cSETUP  i2cmaster,%11100000, i2cfast, i2cbyte
    PAUSE 1 ; wait 1 ms for the display chip to initialise
    Hi2cOUT ($21) ; start clock/oscillator
    ' $00 turns off the whole row
    Main:
    Hi2cOUT ($80) ; clear the display
    ' turn on all LEDS in each column (%11111111=$FF)
    ' x = don't care (not connected) but I have used $AA
    '    start !  col0 x  , col1 x  , col2 x  , col3 x  , col4 x , col5 x  'col6 x  , col 7 x
    Hi2cOUT $00, ($FF, $AA, $FF, $AA, $FF, $AA, $FF, $AA, $FF,$AA, $FF, $AA, $FF,$AA, $FF, $AA)
    Hi2cOUT ($81) ; turn on the display
    ' now draw a smiley face
    '  xxxx
    ' x    x
    'x x  x x
    'x      x
    'x x  x x
    'x  xx  x
    ' x    x
    '  xxxx
    '    columns
    '7 6 5 4 3 2 1 0
    '0 0 1 1 1 1 0 0 row0
    '0 1 0 0 0 0 1 0 row1
    '1 0 1 0 0 1 0 1 row2
    '1 0 0 0 0 0 0 1 row3
    '1 0 1 0 0 1 0 1 row4
    '1 0 0 1 1 0 0 1 row5
    '0 1 0 0 0 0 1 0 row6
    '0 0 1 1 1 1 0 0 row7
    'Adafruit logo at bottom
    'MOVE TOP ROW (ROW0) TO bottom (MSB) AND SHIFT EVERYTHING ELSE DOWN=>BIT0->BIT7, BIT7->BIT6, BIT6->BIT5
    ' becomes....
    '    columns
    '7 6 5 4 3 2 1 0
    '0 1 0 0 0 0 1 0 row0
    '1 0 1 0 0 1 0 1 row1
    '1 0 0 0 0 0 0 1 row2
    '1 0 1 0 0 1 0 1 row3
    '1 0 0 1 1 0 0 1 row4
    '0 1 0 0 0 0 1 0 row5
    '0 0 1 1 1 1 0 0 row6
    'for example, after shifting row 0, column 0 becomes %00011110 or $1E
    Hi2cOUT $00, ($1E, $AA,$21, $AA, $CA, $AA, $D0, $AA, $D0,$AA, $CA, $AA, $21,$AA, $1E, $AA)
    Hi2cOUT ($E0) 'dim the display (range $E0 to $EF)
    Hi2cOUT ($EF) ' full brightness again
    Hi2cOUT ($83) 'blink the display ($83=2Hz blink, $85=1Hz, $87=0.5Hz)
    pause 3000
    Hi2cOUT ($80) ; turn off the display
  2. #2
    Join Date
    Feb 2010
    Location
    Don't Mess With My Texas!
    Posts
    2,566
    Blog Entries
    7
    Default
    Steve, there's been quite a lot of code on the forum about driving the 8x8 displays, but not the particular Adafruit i2c display that you are referring to.
    I have built a double-digit display using a 20X2 with I/O via i2c. Adafruit might have made that job a bit easier for me.
    EDIT: You might also find some inspiration at this link: http://www.picaxeforum.co.uk/showthr...ent-LED-Driver
    Last edited by Texasclodhopper; 05-02-2017 at 15:51. Reason: Added link to MAX7219
    - Tex
    These words are my opinion, WYLION. Any resemblance to truth or fiction is accidental at best.
    "Truth lies dormant in our future history." ― Tex Clodhopper LXVI
    "Confidence is ignorance. If you're feeling cocky, it's because there's something you don't know." ― Eoin Colfer, Artemis Fowl
  3. #3
    Join Date
    Nov 2012
    Location
    London
    Posts
    271
    Default
    I found the 8x8 matrix tricky until I worked out what was going on. I think they must have designed the backpack for 7-seg plus decimal point then, when porting to 8x8 matrix found that row0 was connected to the backpack on the same line that the decimal point from the 7-seg was connected to. Not very intuitive!
  4. #4
    Join Date
    Jun 2012
    Location
    australia
    Posts
    1
    Default
    Hi guys, thanks heaps for posting that code! This had me scratching my head for a while until I found this link. I got it working with an 08m2, but tried to write a similar program for a 14m2 and a 20m2, but to no avail. For some reason I couldn't get it to even start. I'm sorry if this is a stupid question as I'm fairly new to all this, but how would I go about making this work for 14m2 and/or 20m2 chips and what would I have to change?
    Cheers,
    Eli.
  5. #5
    Join Date
    Jan 1970
    Location
    UK
    Posts
    24,373
    Default
    Quote Originally Posted by uniformswift View Post
    I2C code for an 08M2 should work on any M2 or X2 chip without change. As long as the correct pins are used for the SDA and SCL connections it should just work.
    The only thing I note which is 08M2 specific in the code here are the two "Let dirsC=" and "Let pinsC=" commands at the top. You could try commenting those out but I would not have expected them to cause things not to work.
    The other thing to try is replacing the I2CFAST in the HI2CSETUP command with I2CSLOW.
    If it is your own developed code you are using it may be worth posting that in case there is something which requires change to make it work on other than the 08M2.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
