I've been using 6.0.8.10 for some time with minimal problems. Is there a confidence problem with using PE6? I've been using PE6 for years now and most significant bugs have been ironed out.I have installed the latest editor, and used it to program several devices with all code that I have written in the past. No issues so far.
Thanks, but they have to remove or rename PICAXE-Editor-6 Release NotesHelp -> About -> Check for updates will both check for updates and show release notes.
Not quite sure how you mean. The release notes / revision history gets added to as new versions are released. If you are saying the page is out of date then you may have accessed it between the executable being updated and the release notes being updated or it may require a page refresh.Thanks, but they have to remove or rename PICAXE-Editor-6 Release Notes
This link toNot quite sure how you mean. The release notes / revision history gets added to as new versions are released. If you are saying the page is out of date then you may have accessed it between the executable being updated and the release notes being updated or it may require a page refresh.
Thanks that clarifies the context. It is an ambiguity of English that Release Notes can mean two things; notes about the release of a product ( making a creation public ) and a list of what has changed to bring about a new version of that product. I would guess that is at least a part of why we have Revision History on the tab.This link to
PE6.pdf = PE6 Beta Testing Briefing – Sep 2013
Did you try clicking the link ?
I am not sure that we have but will investigate. It always helps to detail what OS and which browser version is being used, and provide as much detail as possible, or even a hint, as to what we should be looking for in case it is not immediately obvious.Have you noticed that Blockly 1.3.2 is not working well in Firefox when you switch between Code and Blocks?
