Thanks, will do .You do such good work, Edmonds. It has been quite a ride you have shared with us here. Thanks, and motor on.
OK : that is the good way !put the magnetometer in the car along with external EEPROM and record a few laps of my test track and then blurt it out to Excel to see if there is any pattern in the data to be recognised.
Edmunds
Ok, I understand why this would be good, but that is another new jig. Or maybe a stepper motor. If I take a stepper motor with resolution of 1.8 degrees per step, I can record 200 measurements. I think this is easier than making something manual. Hmm.Before running it on the track, it'is very usefull to rotate the sensor 10° by 10° (from 0 to 360°) and record corresponding data (X and Y).
Well done... Y data make a beautifull SIN :I now have 5 sets of 48 samples per full turn (7.5 degree steps). Video below and text file attached. No steam to do anything with the data tonight.
You are reading my mind . I must have fogoten all about Excel formating. Sticking a semicolon in now. Will add the third axis. Coming in a minute.Well done... Y data make a beautifull SIN :
But I suspect X data is vertical...
Please try with all 3 data : X, Y and Z so we can choose what is what.
Please, make data "Excel compatible" :
X Y Z
39 26367 12345
58 27135 12333
66 26879 12221
85 27903 12123
YES ! We have now a beautiful SIN/COS :Here is something that works. X is now fixed (there was a bug in the code) and numbers are signed after I learned what PITA it is to do this in Excel .
X Y Z Alpha
13824 29183 12544 -98,9
17152 27903 13568 -91,1
23040 27647 12800 -78,4
24576 29439 13824 -74,1
27648 30207 13056 -66,9
31744 30719 13056 -58,4
-30720 32511 12800 -50,9
-28672 -29697 13056 -42,6
-26112 -26881 13824 -34,1
-24064 -26625 13056 -31,3
-22528 -23297 12800 -23,5
-22272 -17921 14080 -12,0
-22272 -16897 14592 -9,7
-21760 -14337 13568 -3,8
-21760 -10241 14336 5,5
-23808 -6145 14336 15,7
-23296 -2817 14592 22,6
-26112 -1281 15616 28,5
-27392 2560 14336 37,6
-27904 3072 15104 39,2
-31744 7168 16128 51,9
30208 6656 17152 57,9
28928 8960 15872 63,3
25856 12032 16896 72,2
20224 10240 16896 83,8
17664 10496 16384 90,0
12288 12544 17664 101,6
8960 11264 16128 109,3
6656 9472 16128 115,6
4096 8704 17408 121,5
512 7680 16896 129,1
-769 5632 17408 134,2
-3073 3840 16896 140,5
-4865 512 17920 148,8
-7169 -2305 16640 156,6
-6913 -5121 16128 162,3
-8449 -9985 17152 173,9
-6913 -11265 15616 176,6
-6401 -17409 15616 -168,5
-6145 -18945 15104 -164,7
-5377 -22785 14592 -155,6
-3585 -24065 14592 -151,0
-1281 -27137 14848 -141,7
512 -29185 14080 -135,1
1792 32767 13312 -127,3
4096 32767 13056 -123,1
7936 29951 13568 -112,3
Yes they are : X^2 + Y^2= ConstantAren't X and Y related to each other?
ATAN2 to be exact. This is the only one I know...arctan is still an OK option and then we have a single number.
Is 350° more or less that 5° ?If actual is less than what we need - go right (CW), if more - go left (CCW).
I usually use Excel (cloud graph) but theses numbers do not look like coordinates. What are they supposed to be ?Do you have any suggestion on how to plot the data from the Map file? Just out of curiosity, strictly speaking it is not needed.
I will try to get the connection between main picaxe and steering co-processor working now.
Edmunds
They are raw, but signed and decimal data from magnetometer. The same as for the 360 degree thing + some crap (a lot of it, actually) in the end. If I convert this into an angle and add some line between - approx 2mm long, then I have segments + angle. They should constitute one or two squares depending on how much actually got recorded. I'll look into cloud graphs. I'm sure, there is some crazy matlab thing that takes two weeks to understand, but I would be very glad to avoid it . At least for now.I usually use Excel (cloud graph) but theses numbers do not look like coordinates. What are they supposed to be ?
Of course, people tend to mix them quite often, but I meant ATAN2. Will try to behave .ATAN2 to be exact.
I think this is not a problem at all. It is not a super-fast differential steered robot. My min radius (what the car is capable off with steering wheels hitting one side) is 75mm. This is about 523 segments of 0.9mm that I can measure (my odometer resolution) in a full circle. This is ~0.688° degree declination from segment to segment. There will never be a directive 'go 273° from the current heading'. Clearly, reading every 0.9mm segment and doing something about it is not really possible if going fast (3ms between pulses), but even if I add up 10 segments for 9mm my max. declination from the previous heading is only ~7°. So 12° is always CW from 5° and 358° is always CCW from 5°.Is 350° more or less that 5° ?
Yes, so I have read. What I'm trying to figure out, however, is how to come up with a routine for the car to calibrate magnetometer. Drive a circle or figure eight should suffice physically, but I have not come up with an algorithm for what to do with the data. Just a few hours ago I got some blob of numbers not really making any sense for now into an EEPROM finally . Will get there.You needs to calibrate magnetometer, IE, using few "full 360°" datasets :
- find MIN and MAX value for X and for Y
- adjust zero to be (MIN+MAX)/2
- adjust scale to be (-1;1) or whatever needed for ATAN2
That seems easy. Please, publish your code to do that...So 12° is always CW from 5° and 358° is always CCW from 5°.
Did you manage to do that with Excel ?how to come up with a routine for the car to calibrate magnetometer. Drive a circle or figure eight should suffice physically, but I have not come up with an algorithm for what to do with the data.
For an immediate Nobel prize?That seems easy. Please, publish your code to do that...
No, not yet, just got the hserin to work between the chips. Now need to get some sleep. But I will try something like:Did you manage to do that with Excel ?
With Excel, you have the ATAN2 function...No, not yet, just got the hserin to work between the chips. Now need to get some sleep. But I will try something like:
heading (y>0) = 90 - [arcTAN(x/y)]*180/Pi
heading (y<0) = 270 - [arcTAN(x/y)]*180/Pi
And a special case (which will kind of almost never happen ):
heading (y=0, x<0) = 180.0
heading (y=0, x>0) = 0.0
This is maybe where I got the arctan from. Hmm.
Edmunds
Sorry : there is no Nobel prize for mathematics...For an immediate Nobel prize?
Edmunds
I will try to do this today. The good news is that offsets can be stored in the device registers, so 'permanent' offsets I won't have to waste program space and time for in my code.With Excel, you have the ATAN2 function...
But first, you have to calibrate the sensor.
Depending where you are on Earth :
- X and Y scale factors are not identical, so ATAN is not directly usable,
- measurements are not zero centered ; there are X and Y offsets...
==> #93
My gut feeling is that 4 and 5 should be preferable in terms of execution effort. My steering response speed is a constraint I have to keep in mind. Ideally, I would not introduce any overhead if compared to line following. So the best option is an option that fits in one byte or a 16bit word max to be sent fast over hserout, contains 'a sign' or steering direction and magnitude or number of steps to pulse the stepper with. Some bits of this byte or word should be available for other commands - like stop steering altogether, because we parked and resume steering again, because we are going again.Then you have to (re-)write the ATAN2 function for Picaxe...
and to do that, decide what is your angular unit :
1) 0=>360 ° (within a word )
2) 0=>3600 1/10 °
3) 0 => 36000 1/100°
4) -180 => 180°
5) 0==>65535
That gets my vote, it basically uses "Fractional Binary", i.e. the Most Significant Bit of a Word (or Byte) represents 0.5, the next 0.25, etc.. You can use this for both the angle, i.e. fractions of a revolution (360 degrees or 2 x Pi) and for the SIN and COS values. Or for the actual SIN and COS values you might use the MSB{s} for the sign and/or 1.0 (if you want unity stored exactly).Then you have to (re-)write the ATAN2 function for Picaxe...
5) 0==>65535
The last one is interesting because there is only one possibility for an angle ;
300°+90°=30°.
I have tried ATAN2(x,y) in excel (take first row for an example). This gives 0.44238748. This is radians, so I want to get degrees. I multiply with 180 and divide with Pi and get 25.35979184. If I now put it in the first quadrant, where it kind of belongs, then 90 - 25.35979184 = 64.64020816 degrees. If I subtract 8.05 degrees of E declination for where I am, I get roughy 57 degree heading, not -(!)98.9 as per your example.s) from X and Y :
Code:X Y Z Alpha 13824 29183 12544 -98,9 17152 27903 13568 -91,1 23040 27647 12800 -78,4 24576 29439 13824 -74,1 27648 30207 13056 -66,9 31744 30719 13056 -58,4 -30720 32511 12800 -50,9 -28672 -29697 13056 -42,6 -26112 -26881 13824 -34,1 -24064 -26625 13056 -31,3 -22528 -23297 12800 -23,5 -22272 -17921 14080 -12,0 -22272 -16897 14592 -9,7 -21760 -14337 13568 -3,8 -21760 -10241 14336 5,5 -23808 -6145 14336 15,7 -23296 -2817 14592 22,6 -26112 -1281 15616 28,5 -27392 2560 14336 37,6 -27904 3072 15104 39,2 -31744 7168 16128 51,9 30208 6656 17152 57,9 28928 8960 15872 63,3 25856 12032 16896 72,2 20224 10240 16896 83,8 17664 10496 16384 90,0 12288 12544 17664 101,6 8960 11264 16128 109,3 6656 9472 16128 115,6 4096 8704 17408 121,5 512 7680 16896 129,1 -769 5632 17408 134,2 -3073 3840 16896 140,5 -4865 512 17920 148,8 -7169 -2305 16640 156,6 -6913 -5121 16128 162,3 -8449 -9985 17152 173,9 -6913 -11265 15616 176,6 -6401 -17409 15616 -168,5 -6145 -18945 15104 -164,7 -5377 -22785 14592 -155,6 -3585 -24065 14592 -151,0 -1281 -27137 14848 -141,7 512 -29185 14080 -135,1 1792 32767 13312 -127,3 4096 32767 13056 -123,1 7936 29951 13568 -112,3
Thats a downer, isn't it?Sorry : there is no Nobel prize for mathematics...
Not for me... but you can try Fields_MedalThats a downer, isn't it?
Edmunds
Only three years to practice remaining so I'm eligible .Not for me... but you can try Fields_Medal
You are not wrong.... but I am ! Sorry, there where a mistake for MIN and MAX values...Can you explain what I'm doing wrong here?
If y = 0 or x = 0 or x = y 'Handle special cases
if y < 0 and x < 0 then 'Octants 5 and 4
if absx < absy then 'Octant 5
else 'Octant 4
elseif y < 0 and x > 0 then 'Octants 7 and 6
if x < absy then 'Octant 7
else 'Octant 6
elseif y > 0 and x < 0 then 'Octants 3 and 2
if absx > y then 'Octant 3
else 'Octant 2
elseif y > 0 and x > 0 then 'Octants 1 and 0
if x < y then 'Ocatnt 1
else 'Octant 0
symbol negx = 128
symbol deltx= b10
symbol delty= b11
symbol sect = b0 ; Sector number from 0 (0 - 45 degs) to 7 (315 - 360 degs) MUST BE b0
if deltx < negx then
sect = 0
sect = 7
deltx = - deltx
if delty > negx then
sect = sect xor 3
delty = - delty
if deltx > delty then
sect = sect xor 1
swap deltx, delty ; swap uses 12 - 14 bytes of codespace!
Why not simply using the Picaxe ATAN function ?Here is an interesting idea for ATAN2 approximation:
1. Forget octants and forget ATAN as such. Forget lookup tables.
2. Calculate r = (x-y)/(x+y) for x>0 and r = (x+y)/(y-x) for x<0 for all y>0.
3. Calculate theta = 180/4 - 180/4*r for x>0 and theta = 3*180/4 - 180/4*r for x<0
4. In case y<0, just negate theta.
Done with ~4 degree accuracy in excel or some floating point monster. The best I could get on picaxe due to overflows is 7 degree accuracy, which is likely not good enough.
Edmunds
Picaxe Excel
TAN ATAN ATAN
0 0 0,0
1 0 0,6
2 1 1,1
3 1 1,7
4 2 2,3
5 3 2,9
6 3 3,4
7 4 4,0
8 4 4,6
9 5 5,1
10 6 5,7
11 6 6,3
12 7 6,8
13 7 7,4
14 8 8,0
15 8 8,5
16 9 9,1
17 9 9,6
18 10 10,2
19 10 10,8
20 11 11,3
21 11 11,9
22 12 12,4
23 12 13,0
24 13 13,5
25 14 14,0
26 14 14,6
27 15 15,1
28 15 15,6
29 16 16,2
30 17 16,7
31 17 17,2
32 18 17,7
33 18 18,3
34 19 18,8
35 19 19,3
36 20 19,8
37 20 20,3
38 21 20,8
39 21 21,3
40 22 21,8
41 22 22,3
42 23 22,8
43 23 23,3
44 24 23,7
45 24 24,2
46 25 24,7
47 25 25,2
48 26 25,6
49 26 26,1
50 27 26,6
51 27 27,0
52 27 27,5
53 28 27,9
54 28 28,4
55 29 28,8
56 29 29,2
57 29 29,7
58 30 30,1
59 30 30,5
60 31 31,0
61 31 31,4
62 31 31,8
63 32 32,2
64 32 32,6
65 33 33,0
66 33 33,4
67 33 33,8
68 34 34,2
69 34 34,6
70 35 35,0
71 35 35,4
72 35 35,8
73 36 36,1
74 36 36,5
75 37 36,9
76 37 37,2
77 37 37,6
78 38 38,0
79 38 38,3
80 39 38,7
81 39 39,0
82 39 39,4
83 39 39,7
84 40 40,0
85 40 40,4
86 40 40,7
87 41 41,0
88 41 41,3
89 41 41,7
90 42 42,0
91 42 42,3
92 42 42,6
93 42 42,9
94 43 43,2
95 43 43,5
96 43 43,8
97 44 44,1
98 44 44,4
99 44 44,7
100 45 45,0
Excel Fast
X ATAN ATAN
0,01 0,57 0,59
0,02 1,15 1,18
0,03 1,72 1,76
0,04 2,29 2,34
0,05 2,86 2,92
0,06 3,43 3,50
0,07 4,00 4,08
0,08 4,57 4,65
0,09 5,14 5,23
0,1 5,71 5,80
0,11 6,28 6,36
0,12 6,84 6,93
0,13 7,41 7,49
0,14 7,97 8,05
0,15 8,53 8,61
0,16 9,09 9,17
0,17 9,65 9,72
0,18 10,20 10,27
0,19 10,76 10,82
0,2 11,31 11,36
0,21 11,86 11,91
0,22 12,41 12,45
0,23 12,95 12,99
0,24 13,50 13,52
0,25 14,04 14,06
0,26 14,57 14,59
0,27 15,11 15,12
0,28 15,64 15,64
0,29 16,17 16,16
0,3 16,70 16,68
0,31 17,22 17,20
0,32 17,74 17,72
0,33 18,26 18,23
0,34 18,78 18,74
0,35 19,29 19,24
0,36 19,80 19,75
0,37 20,30 20,25
0,38 20,81 20,74
0,39 21,31 21,24
0,4 21,80 21,73
0,41 22,29 22,22
0,42 22,78 22,70
0,43 23,27 23,19
0,44 23,75 23,67
0,45 24,23 24,14
0,46 24,70 24,62
0,47 25,17 25,09
0,48 25,64 25,55
0,49 26,10 26,02
0,5 26,57 26,48
0,51 27,02 26,94
0,52 27,47 27,39
0,53 27,92 27,84
0,54 28,37 28,29
0,55 28,81 28,74
0,56 29,25 29,18
0,57 29,68 29,62
0,58 30,11 30,05
0,59 30,54 30,48
0,6 30,96 30,91
0,61 31,38 31,34
0,62 31,80 31,76
0,63 32,21 32,18
0,64 32,62 32,59
0,65 33,02 33,00
0,66 33,42 33,41
0,67 33,82 33,81
0,68 34,22 34,21
0,69 34,61 34,61
0,7 34,99 35,00
0,71 35,37 35,39
0,72 35,75 35,78
0,73 36,13 36,16
0,74 36,50 36,54
0,75 36,87 36,91
0,76 37,23 37,28
0,77 37,60 37,65
0,78 37,95 38,01
0,79 38,31 38,37
0,8 38,66 38,73
0,81 39,01 39,08
0,82 39,35 39,43
0,83 39,69 39,77
0,84 40,03 40,11
0,85 40,36 40,45
0,86 40,70 40,78
0,87 41,02 41,11
0,88 41,35 41,43
0,89 41,67 41,75
0,9 41,99 42,07
0,91 42,30 42,38
0,92 42,61 42,69
0,93 42,92 42,99
0,94 43,23 43,29
0,95 43,53 43,59
0,96 43,83 43,88
0,97 44,13 44,17
0,98 44,42 44,45
0,99 44,71 44,73
1 45,00 45,00
Simply using theta=47 * XHere is an interesting idea for ATAN2 approximation:
Edmunds
#macro ScaleABSMagData() 'Scale with sensitivity and make positive, but remember the sign
if MX_word >= $8000 then 'If negative value ...
MX_word = -MX_word / 1000 * 15 'Scale factor fixed at 1.5 for this magnetometer
else 'If positive value ...
MX_word = MX_word / 1000 * 15 'Scale factor fixed at 1.5 for this magnetometer
if MY_word >= $8000 then 'If negative value ...
MY_word = -MY_word / 1000 * 15 'Scale factor fixed at 1.5 for this magnetometer
MY_word = MY_word / 1000 * 15 'Scale factor fixed at 1.5 for this magnetometer
#endmacro
#macro GetHeading
if MX_word < $8000 then 'If X is positive ...
octant = 0 '... it must on the right hand side, lets assume octant 0 for now
else 'If X is negative ...
octant = 7 '... it must be on the left hand side, lets assume octant 7 for now
MX_word = -MX_word 'Get ABS(X) for further calculations
if MY_word >= $8000 then 'If Y is negative ...
octant = octant xor 3 '... xor 0 or 7 with 3 for octants 3 or 4 respectively
MY_word = - MY_word 'Get ABS(Y) for further calculations
if MX_word < MY_word then 'If ABS(X) < ABS(Y), we will move to the oposite octant ...
octant = octant xor 1 '... xor 0 or 7 with 1 for octants 1 and 6 or 3 or 4 with 1 for octants 2 and 5
swap MX_word, MY_word '... since in calculating in the oposite octant, swap ABS(X) and ABS(Y)
M_quot = MX_Word / MY_Word * 100 'Calculate quetient of ABS(X) and ABS(Y)
Heading = atan M_quot 'Calculate Heading with ATAN, 0 to 45 degrees
if bit0 = 1 then 'In case we had moved to the opposite quadrant ...
Heading = 45 - Heading '... calculate the angle backwards
Heading = octant * 45 + Heading 'Add 45 degrees for every octant and the actual angle for Heading
#endmacro
#macro LoadMOffsets
read 0, WORD M_Offset
hi2cout [MAddress], OFFSET_X_REG_L_M, (MO_L_byte,MO_H_byte)
read 2, WORD M_Offset
read 4, WORD M_Offset
#endmacro
'Constants
Symbol MX_L_offset = $0 'Initial offset for X axis, $0 split into bytes for eeprom function
Symbol MX_H_offset = $0
'positive version
;Symbol MY_L_offset = $FF 'Initial offset for Y axis, $5FF split into bytes for eeprom function
;Symbol MY_H_offset = $05
;Symbol MZ_L_offset = $80 'Initial offset for Z axis, $3B80 split into bytes for eeprom function
;Symbol MZ_H_offset = $3B
'negative version
Symbol MY_L_offset = $01 'Initial offset for Y axis, $5FF split into bytes for eeprom function
Symbol MY_H_offset = $FA
Symbol MZ_H_offset = $C4
read 5, Temp
if Temp <> 0 then 'if no device calibration data present in memory ...
write 0, MX_L_offset,MX_H_offset '... load initial magnetometer calibration approximation into memory
write 2, MY_L_offset,MY_H_offset
write 4, MZ_L_offset,MZ_H_offset
X: 54016; Y: 62711; Z: 5887
Heading: 435
X: 60416; Y: 60151; Z: 8959
Heading: 225
X: 60928; Y: 62711; Z: 8959
Heading: 225
X: 61696; Y: 60663; Z: 6399
Heading: 225
X: 60672; Y: 62455; Z: 6655
Heading: 225
X: 60160; Y: 61175; Z: 7423
Heading: 225
X: 60928; Y: 60919; Z: 6143
Heading: 225
X: 59904; Y: 61943; Z: 6911
Heading: 225
X: 61184; Y: 61687; Z: 6655
Heading: 225
X: 61184; Y: 60663; Z: 7423
Heading: 225
X: 60160; Y: 63479; Z: 7935
Heading: 351
X: 55808; Y: 1528; Z: 8191
Heading: 358
X: 53248; Y: 4856; Z: 8447
Heading: 189
X: 51200; Y: 4856; Z: 8447
Heading: 189
X: 47872; Y: 6648; Z: 8703
Heading: 189
X: 47104; Y: 8184; Z: 9215
Heading: 189
X: 44800; Y: 9720; Z: 9727
Heading: 189
X: 41984; Y: 10744; Z: 9471
Heading: 189
X: 40704; Y: 12280; Z: 9983
Heading: 189
X: 39424; Y: 11512; Z: 9215
Heading: 189
X: 36864; Y: 13304; Z: 10495
Heading: 6921
X: 36096; Y: 12280; Z: 9983
Heading: 189
X: 36864; Y: 13560; Z: 9983
Heading: 189
X: 38400; Y: 13304; Z: 10239
Heading: 285
X: 39424; Y: 12280; Z: 10239
Heading: 299
X: 44288; Y: 8696; Z: 10239
Heading: 189
X: 48128; Y: 4600; Z: 10495
Heading: 164
X: 50944; Y: 3832; Z: 10751
Heading: 164
X: 54016; Y: 3320; Z: 11007
Heading: 164
X: 53504; Y: 2296; Z: 9727
Heading: 360
X: 54528; Y: 2040; Z: 9471
Heading: 360
X: 55040; Y: 2040; Z: 9471
Heading: 360
X: 54272; Y: 1272; Z: 9727
Heading: 356
X: 56320; Y: 760; Z: 6911
Heading: 345
X: 57600; Y: 65271; Z: 7935
Heading: 185
X: 57856; Y: 63223; Z: 9215
Heading: 376
X: 59136; Y: 64759; Z: 9727
Heading: 184
X: 59392; Y: 62711; Z: 9471
Heading: 351
X: 61184; Y: 61943; Z: 9471
Heading: 225
X: 60928; Y: 59383; Z: 7423
Heading: 225
X: 62208; Y: 59895; Z: 7423
Heading: 225
X: 62464; Y: 58871; Z: 9727
Heading: 99
X: 63744; Y: 56055; Z: 9471
Heading: 270
X: 63744; Y: 55799; Z: 10239
Heading: 337
X: 65280; Y: 55031; Z: 9983
Heading: 142
X: 769; Y: 52983; Z: 7935
Heading: 325
X: 1025; Y: 52471; Z: 8447
Heading: 105
X: 513; Y: 51447; Z: 10239
Heading: 93
X: 2049; Y: 49399; Z: 7167
Heading: 286
X: 1537; Y: 48887; Z: 8703
Heading: 90
X: 2049; Y: 46071; Z: 7423
[7F]Heading: 90
X: 2305; Y: 44023; Z: 7679
[7F][7F][FF]Heading: 90
X: 4097; Y: 38391; Z: 8191
Heading: 92
X: 1793; Y: 33271; Z: 8191
Heading: 94
X: 4353; Y: 33783; Z: 8959
Heading: 286
X: 3329; Y: 34295; Z: 8447
Heading: 90
X: 4097; Y: 33015; Z: 8447
Heading: 286
X: 4097; Y: 36087; Z: 7935
Heading: 286
X: 4097; Y: 38135; Z: 6399
Heading: 92
X: 5121; Y: 39415; Z: 7679
Heading: 90
X: 4609; Y: 40439; Z: 8447
Heading: 90
X: 3585; Y: 41207; Z: 6911
Heading: 92
X: 2049; Y: 44023; Z: 7935
Heading: 90
X: 3841; Y: 48375; Z: 6655
Heading: 345
X: 2561; Y: 48887; Z: 7935
Heading: 92
X: 1537; Y: 53495; Z: 8191
Heading: 286
X: 257; Y: 53495; Z: 7935
Heading: 95
X: 64512; Y: 55799; Z: 8959
Heading: 270
X: 64000; Y: 57335; Z: 8959
Heading: 270
X: 61952; Y: 61943; Z: 8447
Heading: 225
X: 60416; Y: 61687; Z: 8959
Heading: 225
X: 61696; Y: 64247; Z: 9471
Heading: 351
X: 59136; Y: 65271; Z: 8191
Heading: 195
X: 58368; Y: 248; Z: 9215
Heading: 129
X: 57344; Y: 760; Z: 8703
Heading: 360
X: 56320; Y: 2296; Z: 11519
Heading: 105
X: 55040; Y: 3832; Z: 9215
Heading: 189
X: 52736; Y: 6136; Z: 8959
Heading: 189
X: 50176; Y: 5624; Z: 10751
Heading: 189
X: 51968; Y: 6392; Z: 9983
Heading: 189
X: 47104; Y: 9464; Z: 11263
Heading: 315
X: 44800; Y: 9976; Z: 11263
Heading: 189
X: 43008; Y: 10488; Z: 9727
Heading: 189
X: 40704; Y: 13048; Z: 11263
Heading: 409
X: 37120; Y: 13560; Z: 10751
X: 35584; Y: 14584; Z: 10495
Heading: 411
