V6.0.8.11 multi task simulation hangs at INTERRUPTs RETURN statement.
wccronje
This problem occurs in the SIMULATOR only!
sample program below:-
Multitask program.
Start1 suspends itself.
An interrupt from pinsc.3 contains a PAUSE then: the PAUSE has no effect i.e. it runs past the pause. The simulator stop at the RETURN statement.
Remove the PAUSE and the simulation runs OK.
Remove the START1: section and the simulation runs OK with the PAUSE staement.
V5 simulator runs OK.
Load the program on a chip and it runs OK.
#picaxe 20m2
#simtask all
start0:
'********* SETUP ***************
'let dirsC = %00000011 'switch pins 0 and 1 to outputs
setint %00001000,%00001000
gosub dowhile
Main:
dowhile:
do while bit0 = 0
start1:
suspend 1
main1:
goto main1
interrupt:
bit0 = 1
Welcome to the PICAXE forum.
And apologies for what seems to be odd behaviour when simulating interrupts in multi-tasking programs which we are investigating.
wccronje
I am now using Editor 6.0.9.2 but have much the same problem as in the original post. Simulate the following:-
#picaxe 20m2
#simtask all
'This is to demo a "hang" condition in multi task simulation (Editor 6.0.9.2).
' CONDITION:-
'1) a PAUSE must have been encountered during an INTERRUPT process
' AND
'2) task 1 must be in SUSPENSION when the program reach the interrupt's RETURN statement
' THEN
' the sumulation will "hang" at the interrupt's RETURN statement.
' Remove the pause or resume the suspended task then the simulation will go throuh.
start0:
init_routine:
suspend 1 ' <<<<<<<<<<<<<
Main:
do until pinc.1 = 0
setint or %00000010,%00000010
end
subr:
inc b12
'pause 1 '<<<<<<<<< uncomment this pause and the simulator will get stuck at the interrupt's return below
start1:
main1:
pause 10
goto main1
end
interrupt:
gosub subr
inc b10
'resume 1 '<<<<<<<<< resume the task at least here else the simulation will hang at the RETURN.
Please accept our apologies for not having fixed things fully and thanks for your help in highlighting what causes the issue.
I guess there is some more investigation to do to figure out what the issue may be. I will make a note of that.
